![]() | Home > Technical > Dead Battery - now resuscitated |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2963 ![]() ![]() |
I left my defender 4 months while in Ireland and it still started 😳
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 736 ![]() ![]() ![]() |
The alarm system and tracker are your culprits. I always leave mine connected to the CTEK if not used for over a week. Keeps the battery in good shape.
Hope you haven't ruined the battery. |
ChrisCM Member Since: 10 Jun 2013 Location: Cornwall uk Posts: 572 ![]() ![]() ![]() |
"Hope you haven't ruined the battery."
So do I, another £100 I don't want to spend! I'll be keeping a close eye on it over the next few weeks. Chris 2010 Defender 110 Station Wagon, Santorini Black. |
giles Member Since: 21 Jan 2013 Location: 81600 Posts: 9 ![]() ![]() |
Hi,
I dunno which charger exactly you have, but if it has a 'Supply' setting you can use that to bring the batt voltage up high enough to then be able to switch to 'Charge'... at least I can... |
I've got an MXS 5.0, not a very high output charger, but it will charge within 24 hours and then maintain. It's got no Supply setting hence having to jump start to get the voltage up. 2010 Defender 110 Station Wagon, Santorini Black.
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5318 ![]() ![]() |
If you are going to be away for a bit, its best to disconnect the battery. Just to save it from been drained or put it on a trickle charge as mentioned. Like what you would do with a classic car.
I bought a cheap little battery cut off from Ebay for the rover metro, As I used to only use that car a few times, so the car spent most of its time powered off. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Hi Procta,
Yes, that's the plan from now on, the C-Tek is going to be busy! [/quote] 2010 Defender 110 Station Wagon, Santorini Black. |
CTEK do a range of fittings for a more permanent connection. I used a "CTEK CTE-56382 Comfort Indicator with 8mm Eyelet Adaptors". This fits onto the battery and the indicator gives you the state of charge of the battery using coloured LED's.
I routed it through the seat box using an existing hole and it sits in front of the passenger seat ready for connection to the CTEK unit. |
Baz8046 Member Since: 08 Feb 2016 Location: Chatham Posts: 83 ![]() ![]() ![]() |
The Ctek indicator will fit in a Td5 dash if you don't have electric windows.
Saves having to get to the battery when it needs a charge. ![]() Click image to enlarge Defender Td5 Commercial 2002 Range Rover L322 TDV8 Westminster 2012 Discovery 4 SDV6 Landmark 2016 Last edited by Baz8046 on 10th Sep 2017 1:19pm. Edited 1 time in total |
12S towing electrics plug + Martin's connector. Simples.
![]() Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
This what I currently use, I have a 50A Anderson connector on a fly lead connected to the battery via a 50A midi fuse that I use for my compressor etc. I've made up a 50-30A Anderson connector adapter and cut the ring terminals off the C-Tek lead and replaced it with a 30A Anderson plug, this gives a quick and simple connection without having to access the battery.
![]() Click image to enlarge But, I also have one of the comfort connectors just haven't figured out where to mount it. Also, what about the constant current drain from the LEDs? ![]() Click image to enlarge 2010 Defender 110 Station Wagon, Santorini Black. |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3796 ![]() ![]() ![]() |
So, a question for you guys.
When you are charging your battery with a Ctek, and you have a "quick connect" connection outside the battery box, you don't open the seat box, don't worry about the battery being charged in an enclosed space etc? Pickles. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17842 ![]() ![]() ![]() |
Assuming it is the original battery, it is vented underneath the seatbox.
The battery is charging in an enclosed space every time you start and drive the car. The CTEK is not a rapid charger, and as Blackwolf says the battery is / should be vented anyway.
