Home > Puma (Tdci) > Dash switches - can the locations be swapped?
Vitesse
This might be a daft question, but does anyone know if you can chamge the position of the switches (wash/wipe/fog/ TC/heated windows etc) on the puma dash? I.e. are they keyed to fit specifc slots?? if that makes sense? Thanks... Thumbs Up 2015 90 XS Santorini Black
Post #648633 6th Sep 2017 4:25pm
myonehere
2007 Defender 90 Puma 2.4 HT Cairns Blue
Yes -they are ''keyed''' ... but a quick slice with the Stanley Knife sorts it...
Post #648635 6th Sep 2017 4:29pm
Vitesse
perfect.....thanks. Thumbs Up 2015 90 XS Santorini Black
Post #648636 6th Sep 2017 4:30pm
zsd-puma
As above regarding the keying, the other limiting factor might be the cable length. It depends which ones you want to with each other, but you might have to extend the wiring a little
Post #648672 6th Sep 2017 8:42pm
Hendrix
England 2013 Defender 110 Puma 2.2 USW Santorini Black
I have a blank on the top left switch position. Can you get a switch for here without the symbols or with a different light symbol. Do any models use that position. Is there any wiring already in the loom?
I want to add some extra lights and would like to use that position.
Post #648734 7th Sep 2017 7:57am
greenlandrover
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Tonga Green
It's normally taken by an auxiliary light switch YUG000540LNF
Later models have a stability/traction control switch here I think??? When you fit aux lamps to a vehicle with this switch present you have to cut the dash to suit as per VPLDV0103 instructions: -
Post #648738 7th Sep 2017 8:20am
Martin
Site Admin
The other option for a DSC equipped Defender (and if you never use the DSC switch) is to relocate the DSC switch inside the dash, freeing up its spot.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #648752 7th Sep 2017 10:24am
Hendrix
Found a full copy of the instructions thanks, I have a blank the left of the three so shouldn't need a hole. Local dealer couldn't even find a different switch for me.
Post #648938 8th Sep 2017 8:03am
