![]() | Home > Puma (Tdci) > Clutch exchange |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2497 ![]() ![]() ![]() |
Knocking sounds at all temperatures? They tend to knock when the whole system is hot (ie. highway speed).
As far as I understand the Transit type clutches will result in rattling on the input shaft. Some claim no noise at all. Puma 110" SW ............................................................. Earth first. Other planets later |
jpm Member Since: 05 Sep 2017 Location: Moscow Posts: 4 ![]() ![]() ![]() |
I haven't noticed actually but it knocks mainly after driving for some time. So yes, when the system is hot, I suppose.
For me reliability of the clutch would be the key thing. Any noise is find since it'd a Defender… ![]() |
100inch Member Since: 15 May 2012 Location: Brunswick Posts: 411 ![]() ![]() ![]() |
Just replaced mine, original one. Old one did 78k miles with some heavy towing. Friction material still ok but springs had some play. Guess an other 10k more and I could have been in troubles. m
![]() Click image to enlarge ![]() Click image to enlarge |
NinetyTD4 Member Since: 22 Apr 2011 Location: North Posts: 397 ![]() ![]() ![]() |
Daily driver, heavy towing, 180k from 2011, still first clutch, no complaints, working fine. Never forget: cars have owner, Landrover have field service personnel.
Phil VM2.5 Member Since: 28 Mar 2012 Location: Limelette Posts: 196 ![]() ![]() ![]() |
Hi,
For me 140.000km Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 |
lonewolf Member Since: 23 Oct 2013 Location: North East England Posts: 210 ![]() ![]() ![]() |
Hi mine is 2010, no replacement, 32,000 miles.
Fiebre Member Since: 24 Jun 2015 Location: Sabadell Posts: 25 ![]() ![]() ![]() |
Hi,
Mine 2009 1st time with 120000 km |
Howard Member Since: 06 Nov 2012 Location: Oxfordshire Posts: 45 ![]() ![]() |
My 2914 had a new clutch at 72,000. Current millage 83,000.
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1297 ![]() ![]() ![]() |
had mine done today 95000 km. LOF standard kit plus output shaft. Not that the old one had broken but having read the many posts on this subject I thought borrowed time etc..
The indy who did the job said a couple of springs on the old clutch were near to going 'ping'. Of more concern the output shaft splines were fairly worn with not a drop of factory grease and it was an absolute pig to extract. The gear change is quite a bit tighter and lighter with a quick, sharp biting point which I quite like. A bit like a family hatch actually. Its 8 years old so wondering what else is on the verge of failure. I intend to keep it so it will end up like trigger's brush probably |
DG123 Member Since: 29 Aug 2015 Location: North West Posts: 138 ![]() ![]() ![]() |
Changed mine at 70K miles on 2012 model with LuK clutch. Friction pad still OK for many thousands of miles but springs were shot (rattling around and on the verge of falling out). Replaced output shaft at same time with standard LR part - was in a sorry state with high likelihood of imminent failure.
Drive was transformed - all clunks/bangs on taking up drive eliminated. Frustrating and expensive having to replace two badly designed/assembled components before the end of their expected lifetime 2012 110 XS SW Orkney Grey 2003 D2 Td5 Black [SOLD] |
