Home > Td5 > Problem Fitting New Courtesy Light Switch!
Woodruffsdad
United Kingdom 2005 Defender 110 2.5 TD SW Zambezi Silver
I needed to replace the courtesy light switch on the rear (load area) door of my 2005 Defender 110 Td5 Station Wagon but the wiring had disappeared into the bodywork. I removed my rear speaker and fished around but I can't find a wire with a female spade connector which is what I need to connect to my new switch which is a PRC8548. The wire appears to be on a very short lead and seems to be a large male connector protruding from a plastic block. It's very difficult to access or see what I'm doing!
Any suggestions or a diagram please? I've Googled but found no help 2005 Defender 110 Td5 Special Vehicles Station Wagon Zambezi Silver With Black Roof And Black Wheel Arches/Eyebrows.
Post #648462 5th Sep 2017 5:24pm
ibexman
Take off the speaker panel
Post #648463 5th Sep 2017 5:27pm
Woodruffsdad
How please? 2005 Defender 110 Td5 Special Vehicles Station Wagon Zambezi Silver With Black Roof And Black Wheel Arches/Eyebrows.
Post #648481 5th Sep 2017 6:54pm
mk1collector
I'm only guessing here but is the large male connector just the end of the old switch your replacing still plugged into the wire you need? If so pull it out and fit the new switch. Ray
My build thread
Post #648482 5th Sep 2017 6:57pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Take a picture and post it of your speaker surround. We'll be better able to help you out. They are pretty simple to remove... 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #648523 5th Sep 2017 9:24pm
dorsetsmith
Post #648558 6th Sep 2017 8:09am
Woodruffsdad
Here are a couple of photos which, hopefully, will help!
Post #648571 6th Sep 2017 10:08am
mk1collector
 Ray
My build thread
Post #648575 6th Sep 2017 10:29am
4RF RDS
Okay not sure if you've sorted this yet but unscrew the rusty screw [RED] then wiggle the plunger switch out of the hole...and the wire should be attached (its purple). If it is not pull the panel off [Yellow arrowed]. It is just attched with spring clips, just carefully pull it back (as in away from the window). Find the wire run it through the hole attach it to the new plunger switch, reinsert it back through the hole and clean the rust off the crew before putting that back together. Then reassemble everything.
1967 MGB GT
Post #648621 6th Sep 2017 3:14pm
Woodruffsdad
Thank you. I got the panel off easily as you suggested and the problem was very apparent! The old switch had broken off inside the female spade connector. Now all I need to do is to attach a new wire (to make it longer - it was far too short) then attach a new female spade connector and Bob's your uncle! P.S. what strength wire should I use? Photos of my broken wiring and new switch attached.
Post #648638 6th Sep 2017 4:40pm
dorsetsmith
1mm thin wall cable used by LR
Post #648639 6th Sep 2017 4:46pm
Woodruffsdad
Thumbs Up 2005 Defender 110 Td5 Special Vehicles Station Wagon Zambezi Silver With Black Roof And Black Wheel Arches/Eyebrows.
Post #648640 6th Sep 2017 4:53pm
4RF RDS
That picture is indicative of water ingress and I'd recommend first trace the leak, and seal it up. Then you should add some dielectric grease to the contact inside the spade connector to stop that corrosion from happening again (should it leak some more).
Good luck! Cheers 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #648651 6th Sep 2017 5:48pm
