Home > Td5 > Help ordering brake components (discs and brakes)
MalteseRover
Malta
hi.
Did the Td5 leave the factory with solid discs or vented discs?
Currently it has solid discs on the rear and cross drilled/vented discs up front. Makes it feel like an upgrade effort.
one rotor is developing a wavy surface and i would like to buy a suitable/complete set to cover all corners.
Are the calipers it has suitable for both vented and solid discs? Are brake pads interchangeable or there are some more suitable for vented/cross drilled discs?
FTC902 = vented discs (delphi) at 46 a pair.
SFP000260 = brake pads for front axle. (manufacture names: britpart/ferodo/mintex/ap/ebc)
With regards to the rear brakes i am at a loss as there are so many different part numbers Sad
Am i one the right track? (i am using different LR supplier websites to cross reference the numbers since i don't have a TD5 parts book) new.lrcat.com and retroanaconda as well
Many thanks in advance
Bow down
joseph - time for an aspirin
Post #648231 4th Sep 2017 3:55pm
miker
I believe they all had vented discs up front. If you have vented now, then you should replace with vented. No sense going to solid.
On the rear axle it depends on what axle you have. Early Td5s had the old salisbury disc axle, later TD5's have the rover type rear axle. Plenty of photos out there to help figure out which! Other than that, use the VIN code, sites like paddocks are pretty good at declaring which VINs which parts work with.
Post #648236 4th Sep 2017 4:02pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
You can check your correct Part Numbers here. You'll need your serial number (last eight digits) from your VIN.
http://www.allbrit.de/NAV.cfm?PAGE=374979&SPRACHE=EN
 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #648244 4th Sep 2017 4:44pm
MalteseRover
Malta
sorry for being so daft.. forgot to put the details of the motor. it is a 2003 crewcab. well it was.. as it is down in parts up to 50% Sad doh... it does not have abs or traction control. not sure if removed by PO or not installed.
the rear diff is a rover type, def not salisbury. i am from Malta and don't wish to ship in not matching parts.. i will have a look at the diagrams. thanks a lot.
ordering parts for the series3 was so much easy no headaches involved Whistle
joe
Post #648280 4th Sep 2017 6:54pm
