![]() | Home > In Car Electronics > C42 tape deck head unit removal - Newbie! |
| AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1076
I took one out a long time ago. Seem to remember that I struggled with the holes too. In the end, I pretty much removed the whole of the double-din panel to get to the bits holding the radio in.
Sorry I can't be more specific, it was nearly 10 years ago. |
| rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2243
Think that is what was in mine when i bought it. From memory the two holes have grub screws in which you have to slacken off (not remove) to release the radio. Once loose you should be able to pull it clear.
Stteve 02' 110 TD5 Double Cab Rebuild Thread |
| greenlandrover Member Since: 09 Jul 2017 Location: Stourbridge Posts: 145
Allen keys are what's needed.
As Steve said, slack off the screws and it'll come out The screws push a plate out to stop the unit being removed. |
| Trevor110 Member Since: 29 Aug 2017 Location: Guildford Posts: 16
Thanks guys, that was perfect. Much appreciated
| All times are GMT |
