![]() | Home > Maintenance & Modifications > Puma Additional Driving Lights - Advice Please |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 ![]() ![]() ![]() |
Have you considered a lower cost upgrade to your headlights rather than the expense of additional lights? You can get a pair of clear lens headlights for less than £40, and with some higher spec H4 bulbs, such as Osram Nightbreaker Plus or anything else of a similar nature, you'd probably see a significant improvement. I have bought the bits to do mine, but haven't got round to it yet. If you want additional lights, fair enough, just a suggestion if you are just wanting improved vision.
Tris. |
RFT Member Since: 13 Nov 2010 Location: Yorkshire Dales Posts: 693 ![]() ![]() ![]() |
Thanks, I'll look into headlamp upgrade, I wonder if there are upgrades that can be easily adjusted between driving on the Left & Right as I hate putting those sticky things on at the ferry terminal.
Richard 130 Puma HCPU with an Artica 240LR Demountable Camper |
These are the headlights that I bought. They also do some that have a pilot light in them too. There are lots of different upgrade H4 bulbs that you can buy, I went for Osram ones.
I haven't ever heard of anything that is suitable for use driving on both the left and right. I think you'd be unlikely to find anything as the beam pattern has to switch from one side to the other, which would basically mean mirroring the whole headlight. You never know though, might be worth some research! Hope the link is of help, gives you an idea of the sort of thing I'm talking about ![]() |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1857 ![]() ![]() ![]() |
I think these that Greenmachine fitted from Paddocks are the same as I fitted, with the Osram uprated (but still 55Watt) bulbs - really good lights although I do miss my KC Daylighters! And a strip of gaffer tape does the dipping problem on our regular French trips.
Cibie used to make a changeable pattern 7" headlight, fitted to Renault 4s I think but would be pre E marked and certainly pre H4 (P432? or something similar) Lastly to reach the back of the bulbs to effect a L - R dip swap, would you have to remove the lights? If so you could just swap for LHD versions. |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 764 ![]() ![]() ![]() |
...sorry to ask, but what is the diference between those lamps you sugested and the original ones that come with our Defenders ?
![]() Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
These ones have a clear lens and the beam focussing pattern is in the reflector at the back of the bowl. Standard Defender lamps have a smooth reflector (I think?) and the focussing pattern is moulded into the plastic lens. As I haven't installed them yet, I can't comment on the extent of the improvement, but have heard from many others that it is significant. I think having the clear lens, rather than the 'cloudy' effect of the standard units gives a clearer beam. For me, it's largely to do with looks! I just prefer the look of the clear lenses - I find the standard lights on my Td5 pretty adequate for most things. |
Crystal lights, all the beam pattern is done with the reflector, dipped beam cut off is sharp, light output is better. The Osram bulbs are superb as well - better output for the same wattage.
Worth a try as they're not too expensive. |
There you go! Two explanations at the same time!
Is that information overload? - At least we said the same, wise men say the same, fools seldom differ!
![]() Time for bed said Zebedee. |
Ickle
I thought wise men rode camels Are you in Broadway in Pembrokeshire? Richard 130 Puma HCPU with an Artica 240LR Demountable Camper |
Hi RFT, no sunny Cotswolds!
