![]() | Home > Puma (Tdci) > Immobiliser red light dead? |
Sockpuppet Member Since: 17 Sep 2011 Location: Leicester Posts: 479 ![]() ![]() |
Do the interior lights work if you turn them on manually or not at all?
foiloman Member Since: 23 Dec 2008 Location: Berkshire Posts: 9 ![]() ![]() |
Interior lights don't work at all. I'm thinking faulty earth.
Immobiliser light does not come on at all. Also suggestive of electric fault. Rev counter. I've no idea what problem is here! Cheers... 2.4 110 XS |
I suppose the worst you can do is add a temp earth to the interior lights (assume checked bulbs).
The LED on the dask I'd think would be AS10 fault as it's an LED so unlikley an earth fault as probably earthed via the AS10 or via the same earth as the dashboard in which was I'd expect nothing to work. |
IIRC the AS10 unit actually controls the interior lights so a temporary earth to the former may be a good test. Darren
