![]() | Home > For Sale & Wanted > [For Sale] Brand new Bosch 2.4 alternator |
| Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 982
Is this a genuine part or after market?
Merlin |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
I'll check and pop a photo up
Click image to enlarge Click image to enlarge Click image to enlarge |
| HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 827
Would it make sense to have a spare one? Mine is starting to squeak and it sounds like a bat lives under the bonnet. I was told I would have to replace the bearings as that is what is causing the noise. Plus, there seems to be a rusty splash pattern in the areas surrounding the alternator...
Is it a LR one or OEM?
Merlin |
Surely If it's OEM then it would be LR
Photos above, you decide .. |
I was trying not to use the sh!tpart word and hence used OEM by mistake, I should have said 'aftermarket'. Is it a XIK2977 or XIK2978? The difference IIRC are the ribs on the belt.
Merlin |
it has BOSCH moulded into the end plate.
also has made is GB |
£100 collectef
| All times are GMT |
