Home > Technical > 110 Puma P38 rear diff.
Timcat
United Kingdom 2012 Defender 110 Puma 2.2 SW Indus Silver
So after having a few issues with Land rover service & warranty the 110 is back with us, they have changed the rear diff seal under warranty. Before it went I removed the diff guard to make it more straight forward for them to do & now have gone to put the guard back on & found one of the 10' crown wheel nuts stripped! ( Stud looks fine)Have a look but can't find a part number for these, anyone know? Also am I right in thinking 60nm torque?
Post #646566 27th Aug 2017 12:56pm
It's part # 561196
Post #646580 27th Aug 2017 2:23pm
Retroanaconda
Do you mean the nuts that hold the diff carrier into the axle casing? If so they're just standard 3/8" UNF nyloc nuts.
The crown wheel is inside the diff and I can't see how you would be in there just fitting a guard on?
Post #646581 27th Aug 2017 2:23pm
Devon-Rover
NY606042
are the nuts that that hold the diff in.
Post #646582 27th Aug 2017 2:24pm
Timcat
Sorry for the incorrect terminology, there's 10 studs that come out of the diff casing that attach to the prop ( which In turn secure the wild bear diff guard three at the bottom & two on the top)
Post #646584 27th Aug 2017 2:45pm
