Home > Td5 > ECU |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6050 |
NO, they're different.
Although a disco ECU will work on a defender, and vica~versa, you get lots of errors, and the temparature guage reads back to front. |
22nd Mar 2011 4:15pm |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2232 |
Depending on what ecu you have fitted as standard some of the disco ecus can be converted.
Do you have a standard part number from your ecu ? Pete |
22nd Mar 2011 6:03pm |
Pete, could you list up what the associated ECU's are that can be converted please?
Do you mean that a later flashable type defender can be fitted with a (converted) disco one? What sort of £££ is it to convert a disco ECU? does it become a flashable defender typen then? trying to find a defender ECU at a decent price is nigh on impossible! |
22nd Mar 2011 6:19pm |
NNN000120 def/dis manual
NNN500020 def/dis manual NNN500030 dis auto NNN000130 dis auto NNN000250 dis manual. All above flashable. MSB?????? non flash part numbers are a different deal, though i can convert. Pete |
22nd Mar 2011 6:29pm |
so, all the above can be converted into defender spec?
22nd Mar 2011 7:50pm |
sc70 Member Since: 29 Jun 2010 Location: Tregaron Posts: 261 |
Cheers for help will contact you soon with part no's motor is away at the moment. the ecu that came with the doner car was d2 auto which has now had a new ashcroft auto box, engine has been rewired to a defender loom. At the moment have 3 ecu's two d2 auto's 1 nnn 1 msb and a defender ecu i have borrowed to run car |
22nd Mar 2011 8:33pm |
Yes with exepction of the ????30 and 000250, though can be made to work but its more complex to get correct. Pete |
22nd Mar 2011 9:41pm |
