Home > Puma (Tdci) > 13 Pin Socket Wiring
Sammyboy
United Kingdom 2012 Defender 110 Puma 2.2 USW Sumatra Black
Looking at buying a 63 plate 110USW that I would need to fit a 13 pin socket for towing a caravan. I am convinced I have read somewhere that post 2012 Puma's have a plug under a rear wheel arch where a 13 pin socket loom can be plugged into thereby saving various connections into vehicle. Is this correct? Discovery 4 HSE
Defender 2.2 110 USW XS
Ford Kuga AWD
Discovery 3
Range Rover P38
Discovery - 300 TDI
Discovery - 200TDI
Post #645754 22nd Aug 2017 10:02pm
Yes, they do and so does 2007 on.
The 13 pin does have some extra wiring to add though as well IIRC.
But the general harness is taken from that plug.
There is a plastic section up in there for protection and it is behind there. Thumbs Up _\Hennessey|Venom| F5/___
___\â­ï¸Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_
Post #645759 22nd Aug 2017 10:09pm
greenlandrover
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Tonga Green
I bought the genuine LR loom off fleaBay for a reasonable price.
This link has the instructions for the genuine LR part.
https://1drv.ms/b/s!Akx3E9kPwVCefU9M8kurqjf0b8E
I use mine mostly to keep the battery topped up Thumbs Up
Post #645763 22nd Aug 2017 10:24pm
Sammyboy
Thanks guys, very helpful. Discovery 4 HSE
Ford Kuga AWD
Discovery 3
Range Rover P38
Discovery - 300 TDI
Discovery - 200TDI
Post #645770 22nd Aug 2017 10:52pm
____/🇬🇧🇺🇸\____
Post #645772 22nd Aug 2017 10:55pm
zsd-puma
Genuine LR loom's aren't that much from LR dealers. Not far off the after market kits really.
Plug behind the panel in the rear wheel arch for most functions, then If i recall correctly there are two wires you have to run through to the batter, basically for the battery charging and permanent live in the trailer socket. There is a relay goes in the battery box and then a wire from this to an ignition live on the dash (to switch the relay for the ignition live at the socket) Still an easy DIY job.
Post #645784 23rd Aug 2017 1:18am
xpertoftheseas
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Aintree Green
Thumbs Up zsd-puma
Additional to this, I did it in less than two hours with genuine LR loom for £105 (ebay). Remove old 7 pin and connect new one to same connector. Run the small longer loom as per the instructions to the passenger seat box. Mount one relay, connect the ground wire, and connect the +ve wire. The hardest part is running the green/white wire from the passenger seat box to behind the dashboard to connect to the fog light switch (ACC).
Easy job by even the most ham-fisted owner. My 10th Land Rover, but my first Defender.
Post #646074 24th Aug 2017 1:44pm
AndyS
You say that but I can't even find the panel in the wheel arch. Laughing
Post #646306 25th Aug 2017 6:34pm
It's above the rear x member internal under the rear arches. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
Post #646324 25th Aug 2017 7:47pm
zsd-puma
behind the drivers side rear indicator. Wink
Post #646375 25th Aug 2017 11:54pm
