![]() | Home > Technical > U-Pol Raptor |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20884 ![]() ![]() |
Upol is a great brand.
Much depends on if you've got a standard finish chassis or it's already been treated with a wax of sorts. If it has I'd forget it, as once it's waxed you cannot really paint unless it's a massive cleaning job. Even then I wouldn't do it. This is why when I done mine I stonechip sprayed my arches etc then Dinitrolled. ![]() ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ Last edited by custom90 on 25th Aug 2017 7:39pm. Edited 1 time in total |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 ![]() ![]() ![]() |
Waxoil it, raptor isn't designed to be applied without the surface being prepared and spraying it on a complete defender will also make a big mess as it goes everywhere (I know from using it) 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top 1958 Series 1 Soft-top |
The Fox Member Since: 24 Mar 2014 Location: Shrewsbury Posts: 105 ![]() ![]() ![]() |
It will be prepped before application and I won't be doing it so i couldn't care less if it's messy... I won't be cleaning up for once!
More interested in the longevity of the product and its suitability for undersealing. Last thing I want to do is create a problem for myself 10+ years on if water can get trapped behind it etc. |
The Raptor is more of an abrasion protection paint.
Dinitrolled or Waxoyl are actual underseals with water repelling properties. Dinitrolled is far more advanced. This is what I'm using. _\Hennessey|Venom| F5/___ ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Yeah I'd agree with Steve except I don't know if Dinitol is superior, I went with waxoil when I did my own chassis as I know how to use it 1993 200 Tdi 90 CSW
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7928 ![]() ![]() ![]() |
I'd highly recommend speaking to Craig at Buzzweld, really knows his painting/coatings and sells Raptor and other underseals. Worth taking advice if nothing else. Also obviously speak with Zagato!! James
foxyred Member Since: 16 Jul 2016 Location: Nottingham Posts: 227 ![]() ![]() ![]() |
I would not Raptor where you say unless its been cleaned to bare metal then primed ! It will fail unless all contaminates are removed ,
After all its a plastic so will cover for a whiles then blister off if not applied properly |
