![]() | Home > Technical > Aschroft half shaft with HD Paddock drive flange problem |
Itox Member Since: 25 Aug 2017 Location: Pazin Posts: 5 ![]() ![]() ![]() |
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 926 ![]() ![]() ![]() |
Those flanges look a little think they are the PM770's? not the PM769's right?
They are PM769, is that the right one?
There are two styles of drive flange used on the Defender. The thick style used up to about 1993, then onwards there is the thin style.
The PM669 is the HD version for the thick flanges the PM770 is the HD version for the thin flanges. You have a puma so will need the thin style flange QED the PM770 Hope this helps ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17814 ![]() ![]() ![]() |
Why not use Ashcroft HD flanges, guaranteed to work with Ashcroft HD shafts?
SteveT247 Member Since: 21 Feb 2011 Location: Central Posts: 491 ![]() ![]() ![]() |
As others have said, you need the thinner drive flanges. Mine (below) are Ashcroft but one of my mates has been running the Paddock ones with Ashcroft shafts for the last few years with no problems.
Thanks everyone, I will try to replace them by Paddock.
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2669 ![]() ![]() ![]() |
apologies for the n00b question: why would one fit these drive flanges as opposed to the LR ones? --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
They're better made, stronger, and last longer.
According to Steve @ Crown Diffs, Ashcroft shafts will also accelerate the wear on standard LR drive flanges due to the difference in hardness between the drive flanges and the shafts.
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1855 ![]() ![]() ![]() |
Daft question, but as the flanges are thicker, could a few mm be turned off the outside to allow the circlips to fit?
(as the OP seems to be abroad and with postage etc may be more trouble than getting them spun down in a machine shop) |
I'm not sure you could as there is a rim/lip on them.
![]() Last edited by SteveT247 on 27th Aug 2017 11:07am. Edited 1 time in total |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2216 ![]() ![]() ![]() |
Tbh I would still use standard flanges, they end up being the point of failure as well as being cheap and easy to change.
Much better to break a £10 flange and change it in 10 mins or blow a diff instead... |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3796 ![]() ![]() ![]() |
I think I've read on this forum that there can be difficulties with these heavy duty flanges etc when fitting them with Dual Finish/SVX alloys on a Puma in that the larger "fittings" will not fit under the standard Landrover centre wheel cap on these wheels?
Pickles. |
