Home > Technical > Rear sliding window removal 110sw
Timcat
United Kingdom 2012 Defender 110 Puma 2.2 SW Indus Silver
As per title, first of the new Frontrunner gullwings arrived today & going to fit it Saturday. Just wondered about removing the OEM rear sliding windows, is there a knack to it? It's a 2012 Puma 110 thanks.
Post #646114 24th Aug 2017 6:45pm
Timcat
Well one done, if anyone needs to take one out of a 110 Puma they're not a 5 minute job! Remove the internal plastic trim & the internal locators around the aluminium frame ( they slide to the corners )
Then it's a case of heavily masking around the external frame & using a long thin paint scraper ( ground sharp at the end) to cut through the mastic that bonds the frame to the panel. I also found it useful to use a craft knife from the inside to break the bond between the top of the frame & the panel ( surprising how a couple of millimetres hold the frame in place)
Post #646475 26th Aug 2017 8:36pm
Balvaig
Glad you have managed to get one out successfully. Knew they were bonded but hadn't a clue as to how to remove them.
Hopefully the second one will be slightly easier!
Post #646482 26th Aug 2017 9:07pm
