Home > Puma (Tdci) > TDCi Reliability and Longevity
Page 2 of 2 <12
Walman
United Kingdom 1997 Defender 110 Puma 2.4 USW Java Black
Our 57 plate is 125k and still going nice. Plenty of offers for it! Wink
Post #645879 23rd Aug 2017 3:10pm
Hardly run in! My 07 has now just passed the 213,000 mark.
Post #645938 23rd Aug 2017 7:51pm
Dieselhead
Shocked
My 08 coming up to 99k with no engine issuse. Just a clutch at 60k Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #645950 23rd Aug 2017 8:50pm
Fat Cog
My 2008 (sold in 2013) racked up well over 100k, many of them off road laning and towing a hefty Ifor Williams horse trailer, it was serviced bang on time, looked after well but other than that had a pretty hard life; in my ownership it never really burnt a drop of oil or had any major mechanical issues other than 3 x EGR valves.
Ive had 3 Puma's & as a work horse that can be thrashed, off-roaded or used as a long distance tourer they can't be beaten.
And finally I managed to get 93k out of the original discs & pads (& they still had a few miles left in them)...is that a record?!?! Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains
Post #645968 23rd Aug 2017 9:50pm
Walman
Is it a bit like Trigger's broom though? Wink Only had 2 new engines and a chassis and body, but the odometer is original. Laughing Wink
Post #646029 24th Aug 2017 8:20am
RFT
United Kingdom 2010 Defender 130 Puma 2.4 HCPU Zermatt Silver
Mine is 2010MY and is at 83k miles now, 30% of those miles have been at full 3.5Te all over Europe, 30% driven hard through winding Welsh. With no engine or transmission issues.
Every ford I have ever owned have gone well past 120k miles without an issue, our Volvo V40 T4 also ran like a dream we kept it for 12years.... the same can not be said for some of our other vehicles from "prestige" manufactures - for example our Audi A3 has had more break downs (all engine) than a 80's pop star in rehab!!! 130 Puma HCPU with an Artica 240LR Demountable Camper
Post #646031 24th Aug 2017 8:48am
No, much of it is original. Working from memory, in that 213,000 miles it has had the following parts as a result of failure or wear (as opposed to upgrades);
4 clutches
1 transfer box
1 front diff
1 set of rear halfshafts and flanges
1 set of wheel bearings (ie one wheel set)
3 VCVs
1 turbo hose
1 radiator
Several door hinges
1 dip/main switch
1 main lighting sewitch
2 sets of tyres
3 sets of front brake pads
2 sets of rear brake pads
1 water pump
4 windscreens
1 bonnet catch
And possibly one or two other minor things I can't remember. I have also managed to break two ATBs as a result of lubrication issues which has resulted in two new diffs and sets of halfshafts, but I don't count these since they were down to me not keeping a close enough eye on the axle oil.
Perhaps of more interest, except for the items listed above, all of the engine ancilliaries are original, the gearbox is original, the out[put adaptor shaft splined coupling is original, the front swivels have not needed replacing, the propshaft UJs are original, all of the steering balljoints are original, the srpings are original, all the suspension bushes are original, and the battery is original.
Overall I am happy with the performance to date, although it must be noted that my TD5 Disco 2 (which has done very nearly the same mileage) has needed far fewer bits replaced.
Post #646035 24th Aug 2017 9:10am
Walman
Shocked wow! Looks a long list, but actually as you say all wear/tear over the 213k. Impressive list of originals too!
Interesting how the TD5 has had less repaired though. Our Landy garage man always says the TD5 is the engine he would prefer in a Defender. No reason to sell our Puma though Smile
Post #646054 24th Aug 2017 11:08am
By way of comparison and working from memory again, the equivalent list for the TD5 Disco 2, which has done around 200k miles, is as follows:-
1 clutch
1 battery
1 track rod end balljoint
3 set of tyres
Can't remember how many sets of brake pads, probably 3 front, 2 rear
1 FPR
1 set of fuel pipes, tank to filter
1 ACE pipe (pump to valve block)
1 pair of front springs
1 front propshaft (who was the moron who thought ujs, and the centre bearing in the DC joint, don't need grease nipples!)
2 alternators (who was the moron who put and oil-fed vac pump on the front of an alternator!)
2 window lifters
It is also in need of a transfer box (since the original presently sounds like an underground train accelerating), and the headlining is starting to sag.
Original are all engine parts except as noted above, the gearbox, the transfer box (at present), the axles, all suspension components apart from the springs above, the rear propshaft (including the rubber doughnut!)
Overall I think that this is very good for a 15 year old vehicle with 200k miles.
Post #646055 24th Aug 2017 11:19am
familymad
They like to be used 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #646075 24th Aug 2017 1:55pm
Gurmot
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
My 2010 90 XS CSW has 37k miles. At this rate it looks like it will outlast me!
Post #647619 1st Sep 2017 12:42pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
I totaly agree, my Defenders have averaged 25,000 miles a year, the Range Rover and series vehicles around 10,000. Keeping all that oil and coolant circulating gives bearings, seals and so on no time to "dry out" i.e. they stay lubricated. Of course they have needed proper servicing and replacement parts but I'm convinced that they have cost me much less per mile' in parts and servicing than any pampered weekend warrior. Just because you're offended doesn't mean you're right.
Post #647635 1st Sep 2017 3:08pm
zsd-puma
Same with any car, having them sitting around for long periods can do them more harm than using them every day.
Regarding this original post (which is quite old), The engine and gearbox are straight from a Transit and it's not unusual to find transits with a quarter of a million miles on them. The rest of the car is basically the same as any other Defender and will last as well.
Post #647670 1st Sep 2017 6:32pm
Toplink
[quote="Toplink"][quote="Gwynne_90"]Anyone know about the following service bulletin - was it mandatory to all 2007 TDcis?
Land Rover Service Bulletin SSM38792, 2.4 Puma Engine Knock Noise.
Title: 2.4 Puma Engine Knock Noise.
Type: LD - Defender - All Years - Special Service Messages - Engine
Name / Part No: SSM38792
Info Type: Service Bulletins
Version No: 1
Date Uploaded: 21 Jul 2008
Models: LD - Defender
Last Modified: 21-JUL-2008 09:44
Category: Engine
Symptom: 497000 Engine Noi
Content Issue: Heavy audible knocking heard on start up.
Cause: On start up oil pressures can cause the piston cooling jets, (PCJ), to latch into a zero flow condition. Due to hysteresis effect in design the jets do not unlatch until the engine is warm and the oil pressures lower again. During this time with no pressurized oil jet flow to the lower pistons / cylinder bores, overheat and scuff conditions / damage can occur.
Action: Replace the engine assy but ensure only engines post serial # ELD00080707063602 are used.
This condition will not occur on vehicles post assured Vin# 9A767162.
Engines post the info above are fitted with modified PCJ internal springs and this issue is now closed.[/quote]
Just read this and looked at my VIN Big Cry Big Cry Big Cry and mine now knocks when cold stops after 2 miles. 84k on the clock and oil changed every 6k.
I think I will just drive it on and see what happens[/quote]
115k now and still going well 34 mpg for the last few months.. Its never over in my land rover.
2007 Defender HTop.
1952 Series One 80"
1977 Muir-Hill 111.
2014 Triumph Tiger800xc
1999 Discovery 2 td5
1982 Ransomes TSR300D.
2002 Yamaha XT600e.
2010 Freelander2 (the wifes)
2008 John Deere X140
Post #648032 3rd Sep 2017 7:57pm
tuesdayfox
2013 Defender 110 Puma 2.2 SW Zambezi Silver
It's a defender. It's a truck of which the transfer box needs rebuild around 300k miles and the drive flange may not last 10k kms
You should know what you buying
A new engine is part of the service schedule for a dedender
Very Happy
Post #651976 22nd Sep 2017 6:40am
Page 2 of 2 <12
