Home > Puma (Tdci) > Tow ball drop plate.
Sammyboy
United Kingdom 2012 Defender 110 Puma 2.2 USW Sumatra Black
Is a 63 plate 110USW considered to be a commercial vehicle? The reason for my question is that I am led to believe that although drop plates are illegal post 1998 (approx) on passenger carrying cars they are still permitted on commercial vehicles? Discovery 4 HSE
Defender 2.2 110 USW XS
Ford Kuga AWD
Discovery 3
Range Rover P38
Discovery - 300 TDI
Discovery - 200TDI
Post #645756 22nd Aug 2017 10:07pm
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
I'm pretty sure around those years it varied depending on spec etc. Best way to tell would be look at the VED you pay. If it's the lower commercial rate then you're good with a drop plate. If you're paying £500 then you're a passenger vehicle.
That's how I looked at it anyway. Mines £245 a year so I put a drop plate on it. Smile
Post #645896 23rd Aug 2017 4:47pm
zsd-puma
Yes, all USW's, DCPU's, Vans, HCPU's etc are commercial vehicles regardless of age.
Post #645904 23rd Aug 2017 5:02pm
Sammyboy
Thanks guys that's very helpful.....and good to know. Discovery 4 HSE
Ford Kuga AWD
Discovery 3
Range Rover P38
Discovery - 300 TDI
Discovery - 200TDI
Post #645909 23rd Aug 2017 5:13pm
miker
I'll be honest, commercial or not, I wouldn't be comfortable with the flat plate type of drop plate
Post #645949 23rd Aug 2017 8:50pm
BenB8man
Which type of plate are you referring to? Only ask as I have a Dixon Bate version and am about to take a caravan several hundred miles. Rolling Eyes
Post #645951 23rd Aug 2017 8:56pm
miker
The ones you see that are no more than a bit of 10mm plate with a few holes in. Db drop ladders are far nicer!
Post #645952 23rd Aug 2017 8:59pm
BenB8man
Ah that's a relief! I did think they looked fairly meaty, especially with the supports attached to the chassis.
Post #645958 23rd Aug 2017 9:12pm
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
I'm pretty sure that the Dixon Bate ladder jobbies are rated and type approved.
At least that is what the sticker on mine suggests. 1995 300 Tdi Epsom Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #645960 23rd Aug 2017 9:16pm
leeds
Sammyboy, your summary is basically correct.
Cars from 98 deed towing equipment with an approval mark
Commercial vehicles do not require an approval mark on their towing equipment.
That is the simple thing now throw Land Rover and the Defender models into the equation.
Prior 98 all Defenders can use non approval marked towing equipment
1998 to about 2012 only HT/DC Defenders were classed as N1 commercial.
However in about 2012 ALL Defenders were classified as N1 commercial so no need for an approval mark on towing equipment.
The Dixon Bates towing equipment (Now owned by Al-ko) are approved so can be fitted to any Defender.
2" receivers are NOT approved towing equipment and as such 4x4overlander do not sell them as such.
The dropped plate is made from formed/shaped 10mm steel which improves its rigidity. On the back of the plate is a reinforcing rib welded on.
Hope that helps
Brendan
Post #645976 23rd Aug 2017 10:08pm
Sammyboy
Thanks for all your helpful advice. The reason for my original question is that a 110USW I am considering buying has a LR multi height tow bar fitted that 'may' need to have the towball lowered by about 2 inches to achieve a level caravan when towing. Rather than changing to a DB adjustable tow bar I was wondering whether a simple flat drop plate would achieve the required towball height. Discovery 4 HSE
Ford Kuga AWD
Discovery 3
Range Rover P38
Discovery - 300 TDI
Discovery - 200TDI
Post #645982 23rd Aug 2017 10:34pm
leeds
If towing a caravan with a Defender we would strongly recommend that you get a Dixon Bates shock link.
These days we only tow the caravan with the shock link even if it means stopping the shock link between vehicles.
We have destroyed the towing system on a sub 3 year old caravan with less then 5,000 miles on it.
Was chatting to local caravan guy and he has had 3 caravans in last 6 months with broken A frame and/or bodywork departing front of chassis. All 3 caravans towed by 4x4
Brendan
Post #645986 23rd Aug 2017 10:51pm
Sammyboy
Thanks but thought that was only relevant for old leaf spring Defenders not those with coil springs?? The one I'm considering is a 63 plate 110USW. Discovery 4 HSE
Ford Kuga AWD
Discovery 3
Range Rover P38
Discovery - 300 TDI
Discovery - 200TDI
Post #645990 23rd Aug 2017 11:05pm
leeds
As a 10 USW you are allowed about 1 tonne payload and your suspension will be stiff enough to cope with that payload.
Unless you have specific caravan recovery insurance your standard car recovery policy does not cover recovery of a broken caravan if the towing vehicle is ok. Caravan dealers are worse then car dealers for warranty work and a broken caravan means flatbed recovery and that costs more then the shocklink..
Have only towed caravans with coil spring Defenders and will only tow our caravan with the shock link now. The shock link is not cheap but less then recovery cost and less then price of a new caravan!
Brendan
Post #645998 23rd Aug 2017 11:46pm
Sammyboy
Is this problem with all cars with coil springs or just defenders which presumably have a stiffer suspension? Do you sell shock links? Discovery 4 HSE
Ford Kuga AWD
Discovery 3
Range Rover P38
Discovery - 300 TDI
Discovery - 200TDI
Post #646019 24th Aug 2017 7:05am
