Home > Puma (Tdci) > Crankcase breather and induction leak
Page 1 of 3 123>
Siwynne
Broke down on sat. Recovered to dealer and they have sent me a video today suggesting that the crank case breather is the issue as when they have pressurised the system it has leaked at that point. Does the breather link to the induction system? There is a small amount of oil at this point too. It sounded very similar to a split intercooler hose.
Post #645653 22nd Aug 2017 1:30pm
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
That sounds frustrating,
A very small amount of oil is normal from the crankcase breather.
Do you mean the pipe between the crankcase and the air filter box was leaking?
Post #645865 23rd Aug 2017 1:26pm
Siwynne
Couldn't diagnose it without being able to pressurise the system but dealer did this and said breather was leaking air when a small amount of pressure was applied. It sounded to me very much like a split intercooler hose and behaved in a very similar way. It's been a bit hissy for a couple of days so I was kind of expecting it and had commented the day before that I thought I had a hose on its way out. Not heard from dealer today but will ring later for an update.
Post #645870 23rd Aug 2017 2:22pm
Siwynne
Post #645897 23rd Aug 2017 4:49pm
Siwynne
Just had a call from the dealership which I am not naming YET. They want me to authorise over £1400 of investigative work to just diagnose the problem. No chance as if it is not covered under warranty I will be liable.
12 hours work. I could have the whole engine in nuts n bolts in 12 hours. I have contacted extended warranty and they say they will be speaking to the very short staffed dealership in the morning as they can't get through now.
What good is a warranty if it costs to use it?
Post #645898 23rd Aug 2017 4:54pm
Marks Landy
Is it still within the three year warranty ?
Post #645914 23rd Aug 2017 5:28pm
Siwynne
No I have a two year extended warranty with landrover. Finishes Aug next year
Post #645926 23rd Aug 2017 6:54pm
Siwynne
Even better
They now want me to authorise £1750 of work to remove the head. Extended warranty will now send a tech out to the dealership to check diagnosis and confirm amount of work necessary.
Post #646072 24th Aug 2017 1:29pm
Marks Landy
I don't get why you need to approve cost of warranty work that should be FOC?
Post #646086 24th Aug 2017 3:21pm
Siwynne
Depends on the final outcome and if covered by warranty. I agree though. A customer should not be expected to pay anything with a full warranty. Let's wait and see the final outcome. I am still suspicious of the initial diagnosis but the warranty engineer will confirm this.
Post #646093 24th Aug 2017 4:31pm
Siwynne
Warranty engineer has been out and has confirmed its head off to investigate and fix. On smoke test there was smoke exiting via crank case breather. What is likely to have gone wrong?
Post #647124 30th Aug 2017 9:26am
2.2 or 2.4?
Post #647139 30th Aug 2017 10:44am
Siwynne
Post #647140 30th Aug 2017 10:53am
Marks Landy
Did they confirm it is covered by your warranty?
Post #647143 30th Aug 2017 10:57am
My first suspicions for a 2.2 would be bore damage resulting from oil dilution, or possibly bore damage resulting from variable-displacement oil pump malfuction. Presumably is has had the oil pump recall carried out?
Post #647149 30th Aug 2017 11:26am
Page 1 of 3 123>
