Home > Pictures & Video > Winching Course
Landie Boy
United Kingdom 2010 Defender 110 Puma 2.4 USW Stornoway Grey
Winching Course
On Saturday me and my dad attended a winching course at Rockingham Castle run by Ed Cobley of Protrax.
Was great fun and we would recommend it to any one who has a interest in winching Smile
Here is a link to a Northants4x4 members gallery who was there.
https://picasaweb.google.com/1077517737542...irectlink#
Jack
Post #64556 21st Mar 2011 5:01pm
BigMike
Can I pick up on one of the pics? this one
I would always put the shackle the other way around to stop the pulley block from potentially sliding around and over the eye bolt and possibly giving you a stress point on the corner where it's more susceptible to bending and potentially making the eye bolt impossible to remove + also stressing the pulley block and cable/rope as the block can twist. Not saying "my" way is the "right" way, just wondering what others do and if they taught you to do it in the way the pic shows on the course.
Post #64572 21st Mar 2011 6:39pm
AndrewS
I normally get Ed to come to us Thumbs Up 130's have feeling's as well you know Smile
Post #64574 21st Mar 2011 6:45pm
cwc
That was the way we were told to do it. and you wont bend a 20mm pin
But I do see where you are comming from
David [img]www.northants4x4.com/responseandlogocopy.png[/img]
Post #64582 21st Mar 2011 6:59pm
BigMike
its more if the block ends up in the corner of the shackle or the shackle twists round so that the force is running across it rather than up and down it. just wondering more than anything.
Post #64584 21st Mar 2011 7:19pm
AndrewS
The thing is was this picture taken after they were told to do it the correct way and they got it wrong, or was it a case of 'ok lads rigg up and lets see what mistakes you have made' or perhaps this is the way they were told to do it. 130's have feeling's as well you know Smile
Post #64594 21st Mar 2011 7:57pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
In this case better to put the sling in the bow as; if the shackle travels along the sling the pin won't be unscrewed by the friction with the sling, with a proper load rated shackle such as a crosby the side loading at 90 degrees reduces the SWL by 50% Thumbs Up Original Member Pie n Pea Club.
110 HCPU Tipper
Post #64612 21st Mar 2011 9:01pm
BigMike
Willy I get what you mean but how is the shackle going to travel down the sling assuming the shackle is pointing toward the winch and its at the lowest point on the sling ? not sure from the pic why the sling/tree strap is through the shackle in the way and not the looped ends.
if the shackle is de-rated to half its SWL if the load on it i high due to the vehicle being bogged etc then it wouldnt take a huge amount to cause a failure?
I know this is all hypothetical but I find it interesting (i need to get out more Laughing )
Post #64617 21st Mar 2011 9:27pm
willy eckerslike
True Mike that was the only reason I could see, That looks like a 4.75 ton shackle which will have a safety factor of 6 to 1 so 28.5 tonne breaking load so even if you cock it up by pulling with a side load you are still safeish, the idea behind SWL is to allow for fools and damage. Unfortunately you still see unrated shackles in use by 4x4 owners which as you know can have disastrous results. I think basically the sling was the weak link in that photo and it wouldn't really matter which way round the shackle was. If any one wants rigging manuals etc just PM me Original Member Pie n Pea Club.
110 HCPU Tipper
Post #64631 21st Mar 2011 10:33pm
BigMike
Would be interested to see that Willy Thumbs Up
Post #64633 21st Mar 2011 10:40pm
TACK
Why do you want to see his willy, it ain't a cock contest guys Laughing
Post #64651 21st Mar 2011 11:53pm
cwc
Hi
We were told bow always on the strap by Ed. It is a 4.75 ton tested shakle and a 14 ton strap. the weakest point in this rig is the Defender tie down points the strap is fixed to
Post #64665 22nd Mar 2011 6:51am
Landie Boy
cwc wrote:
Hi
David
Yep Smile
Jack
Post #64666 22nd Mar 2011 8:14am
Landie Boy
Post #64674 22nd Mar 2011 8:56am
walfy
I would of put the pin to the strop and bow to the snatch block. Strange how there is 2 trains of thought here an both think they are right.
Where did everyone learn their offroad craft? Was it taught or just through passage of info from more experience people.
Both sets of people can't be right, there must be a right and a wrong way or the design of the bow shackle wouldn't be needed and you could just use a D shackle? 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #64688 22nd Mar 2011 10:26am
