Home > Td5 > Td5 90 with fuel tank guard?
For those of you that have a Td5 90, with an extra bolt on fuel tank guard, I have a question.....
Does the "new" thicker beefy guard replace the thin tin thing that usually protects the tank, or does it bolt on top of it?
Reason is i'm building a Td5 90, and have the tank, but no thin tin plate, so figure if i'm going to have to buy said tin plate, I might as well pay a little more and get a beefy one.
cheers all! Thumbs Up Thumbs Up
Post #64454 20th Mar 2011 10:01pm
AndrewS
Don't know if this helps as it relates to a 110, I removed the thin plate LR tank guard when I fitted the thick after market tank guard 130's have feeling's as well you know Smile
Post #64457 20th Mar 2011 10:12pm
markb110
Hi
I have one and bolted it over the original plate so would agree with your suggestion.
Mark
Post #64459 20th Mar 2011 10:15pm
stevie d
United Kingdom 2003 Defender 90 Td5 SW Alpine White
I fitted a Safari Equip one recently. Just fitted it over the original thin one, by removing and refitting some of the bolts. Can't see it being a problem, not having the thin original one in place.
Steve Thumbs Up Defender 90 TD5 Station Wagon
Discovery 3 HSE
BMW 330i Coupe
Post #64494 21st Mar 2011 9:48am
OK, thanks all for the replies. Bow down Bow down Thumbs Up
Next question... does the tank "sit" on the thin guard? or is it just that.... a guard?
If the thin guard is removed, will the tank then "sit" on the new HD guard, or is it supported by other brackets?
sorry for all the Q's! Whistle Whistle
Post #64537 21st Mar 2011 3:16pm
stevie d
I can only talk for the Safari Guard.
Mine sat on the lower side of factory fit guard and supports. From memory I took the 3 large bolts out from each side and the guard is drilled for the same holes.
What I found confusing was the large size of the pre-drilled holes, but as it turned out you are supposed to fit with large washers circa 1" which actually works fine.
Sorry, not answering the question........
Tank does sit on the thin guard and will need supporting, but as it is so thin, I would assume the tank can be supported on the new guard without any probs - would lower tank approx 5 mm.
Discovery 3 HSE
BMW 330i Coupe
Post #64546 21st Mar 2011 3:40pm
johnszs
United Kingdom 2004 Defender 90 Td5 XS CSW Alveston Red
would a tank guard fit with the drop tow bar assembly? 2004 TD5 Defender 90 xs station wagon
Post #65515 29th Mar 2011 6:06pm
T1G UP
mine sits on the guard
Post #65518 29th Mar 2011 6:59pm
Evenin' Marcus
You say yours sits on the guard... which? your aftermarket HD one, or the factory thin tin plate?
Post #65532 29th Mar 2011 9:28pm
T1G UP
on the tank guard, took the flimsy factory on off as it won't protect the tank and it drops the tank down a few mm which helps if you have to change the pump or drop the tank.
do you need the factory flimsy bit?
Post #65673 30th Mar 2011 7:46pm
Will need a flimsy guard until i get a decent one.
mind you, got to a) get my chassis yet, b) fit a Td5 crossmember to it, c) make/buy/weld on some Td5 tank brackets!
Rolling Eyes Rolling Eyes
Post #65686 30th Mar 2011 9:03pm
walfy
2 days till chassis time!! Thumbs Up 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #65695 30th Mar 2011 10:06pm
/evil James Bond henchman voice/
....2 days..... and counting.......
Post #65720 31st Mar 2011 7:32am
T1G UP
as always i'll offer my services but looks like the doozers got it covered
Post #65796 31st Mar 2011 9:54pm
Doozer Question Question Question
I've got a MIG here, and can manage to stick some bits of metal together... just.
Post #65797 31st Mar 2011 9:56pm
