Home > Technical > Anyone got any remote reservoir adjustable dampers?
bankz5152
Anyone got any remote reservoir adjustable dampers that could take a few pics for me?
Any make should fine! Also mention if they are on a road going truck, pure off roader or a mix.
Thanks Thumbs Up
Post #644654 17th Aug 2017 12:12pm
Didn't the very latest 2.2's have something similar? ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #644681 17th Aug 2017 3:00pm
bankz5152
No idea but I can't imagine Land Rover fitting remote res or adjustable shocks to a Defender!
Post #644692 17th Aug 2017 3:52pm
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
there are a few in our club that have them, on CCV cars. What exactly do you want to see, may be a week or two until we see some again though 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #644816 18th Aug 2017 7:18am
bankz5152
Want to get a look at how they adjust, if thr adjustment knob can be removed and what fitting is under it. Working on a way to see if they can be adjusted remotely/in cab like fancy top end coilovers
Post #644830 18th Aug 2017 9:19am
100inch
Australia 2010 Defender 110 Puma 2.4 CSW Santorini Black
You can't remove the adjustment away from the shock body/reservoir as the interfere directly with the oil flow. American brands like Fox do 2.0 entry level shocks with adjusting knobs, but if budget allows have a look at brands like Proflex, Aragosta or Ohlins. They offer 2/3 way external adjustments. m
Post #644963 19th Aug 2017 12:19am
100inch
You can't remove the adjustment valves away from the shock body/reservoir as the interfere directly with the oil flow. American brands like Fox do 2.0 entry level shocks with adjusting knobs, but if budget allows have a look at brands like Proflex, Aragosta or Ohlins. They offer 2/3 way external adjustments. m
Post #644964 19th Aug 2017 12:21am
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
King also do great shocks 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #644968 19th Aug 2017 1:44am
100inch
Picture showing one of the 3 Bypass on my 3"King, with the 2.5" Dual Rate Coilover. No adjustments on the reservoir. m
Post #644973 19th Aug 2017 6:29am
Likeomg
I thought the main reason behind remote reservoir dampers was for better cooling?
I really want a set of king or ohilins remote resevoir dampers but they are probably wasted on a road car, ill stick with bilstein for now,
Post #645060 19th Aug 2017 4:37pm
100inch
Yes, the reservoirs are mainly for the cooling and make shock rebuilds/valving easier too. Did you get a quote for Ohilins?
Post #645162 19th Aug 2017 11:56pm
Likeomg
i asked twisted about them as they stick them on the v8 builds which im currently on with...
i think it was around the 4k mark + vat... hence why they only use on v8 builds..
Post #645199 20th Aug 2017 12:08pm
100inch
Ohilins would be well worth their money but if you want something similar but a tad less expensive Proflex is another great brand. Note that those type of shocks (European Designed) are harder to rebuild and revalve due to having a 'bladder' instead of a floating piston in their reservoir. m
Post #645336 21st Aug 2017 1:13am
