Puma Instrument Cluster Change
Hi, I am new to the forum and was wondering if someone has had a similar issue & a solution. I had put this on the Technical section earlier but realised it is better placed here.
The odometer display on my cluster has faded out so I bought a new cluster. When the LR workshop tried to program it after the install it went through the whole process but wouldn't let it start so they put back the old one till a solution is found. The workshop uses SDD 150.4 software.
The part that needs to be replaced is Instrument Cluster/Clocks: YAC 502810 PUY. The new part which was not being programmed is FH 1210849BB. I have attached a photo of both with part labels which may be able to offer more details & information. I bought the part in UK and was advised it is compatible.
Any assistance will be much appreciated Smile
17th Aug 2017 9:47am
I would have a chat with Gary @ Alive tuning or Pete @ BAS Tuning.
They are incredibly knowledgeable on such this and will likely be able to help you with such issues.____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
