![]() | Home > In Car Electronics > TD5 Fuse Box |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2239 ![]() ![]() ![]() |
In all honesty that is a terrible idea unless you are very good with car electronics. Adding stuff into the original LR wiring can cause all sorts of headaches when trying to chase faults and problems. Not to mention it is an enormous amount of work
Its highly unlikely the heated seat wiring will be there, it certainly wasnt on my 02 90 CSW If you are adding in extras the best bet is to mount an auxiliary fuse box, if you plan on keeping LR seats with removable bases then it can be mounted beside the battery in the seat box, then run all your wiring and mount your relays in there. |
tyrannosauROSS Member Since: 24 Jun 2016 Location: Kent Posts: 136 ![]() ![]() ![]() |
Sure, ok.
I currently have a 100ah leisure battery and the started battery under the passenger seat. I have zero space in there so won't be able to get anything extra in it. I think the starter battery is not the original (in fact I now its not) Im curious to know what size the starter battery should be and what size leisure battery other people have been running to be able to get both these and the cut off switch and the fuse box in there? when the car isn't running the only draw on my leisure is my fridge, a snowmaster classic 60l. it draws about 3a on tick over I think and the occasional iPhone/ipad. Thanks R |
In that case could always mount the fuse box on the bulkhead. Thats what I did with my old 90
Or you could buy one of the various under cubby box trays/storage places and fit the aux box there. |
