Home > Maintenance & Modifications > Steering / handling upgrade
Likeomg
Has anyone had the upgrade to the steering which uses the rrc damper and a new layout of the linkadges ?
A few companies are offering this just wondering if anybody has any feedback?
I can't exactly remember what's involved but it uses bits from the disco 2 with a relocated rrc steering damper...
Post #643705 13th Aug 2017 9:13pm
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
I can't offer any help on the subject but i'd be interested to hear about this as well? 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #643747 13th Aug 2017 11:06pm
bankz5152
Gywn Lewis do a kit that removes the drop arm ball joint if thats what you're on about?
If so I fitted that to my 90 as I didnt want to deal with that stupid ball joint! Steering was improved, slightly tighter and less play once the PAS box was adjusted. Worth while, I'll be doing the same when the balljoint fails on the 110
Post #643870 14th Aug 2017 2:44pm
grafty99
I have exactly this setup. Disco 2 drop arm with sumo bars from Gwyn Lewis with greasable track rod ends. Much more solid feel to the steering with better feedback and far less post bump wheel wobble. 19mm hollow tube to 30mm solid - makes quite a difference Thumbs Up
This is the only picture I have currently
 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #643970 14th Aug 2017 9:08pm
Likeomg
I think Grafty's set up is the one im after.... Sounds like its worth while
Post #644000 14th Aug 2017 10:11pm
bankz5152
Yeah it is a decent bit of kit, plus you get heavy duty Sumo Bars in the process! Though £ for £ it is expensive, I wouldnt change it unless there is something wrong with your current system
Post #644118 15th Aug 2017 11:18am
grafty99
Expensive, but there was nothing wrong with my standard setup and it's made a noticeable improvement Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #644142 15th Aug 2017 1:04pm
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
I fitted the same set-up (albeit it with a drop arm from a scrap 300Tdi D1) about 5 years ago and am very pleased with it. When I come to redo the steering on the 110 I'll do the same again Thumbs Up
The original drop arm ball joints are a pain to replace.
https://gwynlewis4x4.co.uk/product/defende...-hd-steel/
Post #644157 15th Aug 2017 2:16pm
Likeomg
For me i'm currently shipping a 480hp ls3 over from the states so any upgrade to the handling system is worth while...
any ideas on approximate costs? the car is going to be stripped down for the install so might as well do it at the same time.
Kind regards.
Post #644158 15th Aug 2017 2:16pm
bankz5152
Fair enough then!! Laughing
Post #644167 15th Aug 2017 3:18pm
smb
Yep, massive improvement. Had the standard Defender set-up with Terrafirma rtc damper, but the vibrations through to the steering wheel became intolerable even on short journeys. Was forever rebalancing the wheels and adjusting the arms, etc...but could never get it right.
The 110 is raised 1¾" at the front with one hd suspension being weighed down by an ARB Bullbar, winch(wire rope), and patriot rr running on 285/75 Cooper stt pro's on semi-beadlocks.
Gave up in the end and ripped the steering off to put the Gwyn Lewis set on with ome damper and balancing beads. The only improvement I had to make was put some small spot welds on the bar to stop the clamp moving/sliding which you may not normally have to do with a lighter more standard Defender.
Like chalk and cheese with absolutely no vibration and positive steering. Cant believe I put up with it for over 50k miles before doing this, but then I suppose it can be put down to the neverending learning process of Defender ownership.
For my set-up it was well worth doing and cost wise it wasn't a lot for the benefit. Would be one of the first things to do if I get another one. Thumbs Up
Post #644376 16th Aug 2017 10:57am
JOW240725
Makes for interesting reading. Sounds like I'll add this to my list when the damper needs replacing. Thumbs Up James
Instagram @suffolk_rovers
Post #644380 16th Aug 2017 11:12am
Is there that much variation in damper lengths such that it could not be a more permanent solution to that fixing?
Post #686958 16th Feb 2018 2:30pm
