Home > In Car Electronics > Cisbo Parking Sensors Install
bankz5152
Driving me bloody mad! Been at this all day and no joy! Trying to wire them up to a 2004 110 DCPU XS
I've installed the sensors, wired them up and fitted the 'control box' behind the brake light panel in the rear tub.
Red + goes to the reverse light - RDX LUX LED if it makes any odds
Black - goes to the same
Yellow Ignition goes to the cig lighter in the dash
Buzzer is behind the rear seats
When I go into reverse I get BEEP, BEEP BEEP, BEEEEEEEEEP (continuous) and doesn't stop! Tried different earths, different sensors (only two out of 4 plugged in) Still the same issue, nothing in the troubleshooting in the manual either.
Also the 12v yellow ignition cable appears to do nothing at all, plugged in or not the buzzer still goes off.
I've no idea what could be wrong! Normally I would just bin them but I've got a hole cut in my nice Raptor dash and a parking sensor switch so I'd like to get them working if I can!
Any ideas?
Thanks Smile
Post #643672 13th Aug 2017 7:12pm
grafty99
They have an orientation (should have a top mark of some kind) and also standard ones don't work mounted in metal Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #643686 13th Aug 2017 8:20pm
grafty99
The top mark should be on the rear of the sensor Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #643687 13th Aug 2017 8:21pm
bankz5152
Ahhh didnt know there was an orientation!
Dont work in metal? How come? They are inside a plastic and rubber sheath surely that shouldnt make a difference?
Post #643690 13th Aug 2017 8:32pm
VeeTee
Netherlands
Did you get the wiring right? According to the manual (found on the web, but not sure it is the right one) the yellow wire goes to stop (brake) light, red to reverse and black to earth... Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #643697 13th Aug 2017 8:52pm
bankz5152
Interesting, why would it go to the brake light? The wires where labeled yellow clearly had "ignition 12v" on it.
Post #643699 13th Aug 2017 9:08pm
VeeTee
Netherlands
Because when you stop, the buzzer stops buzzing?
Was a manual not included? Cheers, Vincent
MySite
Post #643701 13th Aug 2017 9:10pm
bankz5152
Suppose so but buzzer also stops buzzing when you take it out if reverse!
It did, i followed the instructions and hace an issue hence the post! Contacted the seller as well see if they can shed any light.
What I dont get is why the ignition live actually does nothing, connected or not it still beeps.
Post #643707 13th Aug 2017 9:19pm
grafty99
I'm pretty sure it's to do with the way the sensors generate their pulse and then 'listen' for the echo.
Me and my dad fitted a set of normal parking sensors into the metal bumper on the back of his van. They never worked properly and randomly beeped with nothing there or didn't go off even if you were 6 inches from a wall. Total rubbish! Laughing 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #643721 13th Aug 2017 10:12pm
bankz5152
Bloody hell! Utterly pointless on a defender then as plastic is few n far between! That said ive seen fenders with sensor mounted directly into the xmember!
Post #643725 13th Aug 2017 10:15pm
grafty99
Apparently there are metal specific ones. Or you can get ones with dedicated plastic brackets Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #643730 13th Aug 2017 10:24pm
bankz5152
Hmmmm!! Ill look into it, the ones ive got are a sealed unit, surrounded by a rubber sheath, then wrapped in plastic and mounted into my NAS step. Should be pretty insulated against the metal!
Post #643734 13th Aug 2017 10:29pm
grafty99
https://www.amazon.co.uk/Quanan-Parking-Se...B005FE7T1Y
Taken from the description of the above kit Thumbs Up
The system does not like most of systems in the market that are not suitable for metal bumper, it special designed for both metal and plastic bumper, can be for any Car, Pick up truck, Van, SUV 4*4. 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #643736 13th Aug 2017 10:35pm
bankz5152
Cheers! Ill have my leccy mate double check my wiring and take in account the suggestions above, if all fails ill go for tha.
I went for the Cisbo kit as it had brilliant reviews inc some from landy owners! Im wondering if for some reason the LED light is causing an issue
Post #643740 13th Aug 2017 10:43pm
the gamekeeper
England 2007 Defender 110 Puma 2.4 DCPU Tonga Green
These parking sensors are all over rated, there's nothing wrong with a Dixon and bates when you hear the rattle your in the zone.
Post #643894 14th Aug 2017 5:01pm
