Home > Maintenance & Modifications > Chassis cleaning
Djcla
Chassis cleaning
Has anyone tried cleaning the inside of their chassis with something like this? Wondering if it worth doing assuming it will drain and dry out again lol
Look at this on eBay http://www.ebay.co.uk/itm/112484737178
Post #643504 12th Aug 2017 7:49pm
ickle
I used a 6mm nylon tube, reduced with various bits and bodged onto a karcher, jacked the back up as far as possible and kept pouring the water through, even on a 18 month old truck, the dirt that came out was eye opening!
Left it in that attitude for a couple of days, then swapped the karcher for compressed air, another couple of days then dinitrolled inside and out.
hth Keith
Post #643536 12th Aug 2017 10:33pm
LR90XS2011
I think the most important thing would be ensuring its well dried out before adding the protection, I was amazed the other day having rushed the washing and drying up few weeks ago to find some pans still wet and that was in a warm kitchen cupboard . DEFENDER 90 TDCI XS,
Post #643561 13th Aug 2017 7:59am
cobra_mark
United Kingdom 2000 Defender 90 300 Tdi SW Barolo Black
If the chassis was galvanised would you still apply dinitrol internally?
Post #643563 13th Aug 2017 8:07am
V8GPC
galvanised still degrades overtime, so a nice Dinitrol inside would protect it; but that would any make your chassis last forever rather than for 30 years
Post #643598 13th Aug 2017 12:19pm
cobra_mark
Which Dinitrol product suites best?
Post #643614 13th Aug 2017 2:00pm
I went for 3125 in brown internally applied. (You don't see it and allows you to distinguish.)
Applied first due to possible application run off.
4941 in black for undersealing. I treated and rust spot areas with Hammerite Kurust.
Also an idea to stonechip arches before anything, adds a layer of sound proofing and does work.
This is what I did, only used cheaper Autotek Stinechip off eBay.
Thumbs Up _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #643624 13th Aug 2017 3:08pm
cobra_mark
Thanks for the advice will form my winter prep session next month. Smile
Post #643628 13th Aug 2017 3:56pm
For a 90 you want around 12 cans 6L 500ml each of aerosol of undersealing and 6 cans internal 500ml each 3L with applicator straws
That's with aerosol but if compressor, similar volume.
I used aerosol and had perfect results, but it doesn't unduly matter. Thumbs Up _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #643629 13th Aug 2017 4:01pm
Djcla
so how do you go about treating the chassis internally then is it just a case of spraying through each hole you find? Id been looking at this stuff to do my cross member , or Kurust
http://www.ebay.co.uk/itm/Fertan-Rust-Trea...1438.l2649
Post #643799 14th Aug 2017 9:28am
Djcla
Thats the tricky bit and not sure other than time how you go about that as i dont have a compressed air blower
Post #643800 14th Aug 2017 9:29am
foxyred
England 1994 Defender 90 200 Tdi HT Montalcino Red
I did Very Happy
Post #643962 14th Aug 2017 8:56pm
