Home > Td5 > TD5 cooling system pressurising
fondelli
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
Here is my first post. I recently bought a 90 TD5 as my first Defender. It drove fine on the journey home- about 200 miles. The next morning I got up and re-checked all the levels and I had to add about 4 litres of coolant. There is no overheating (yet). So far the focus has been on peripheral things (cap, tank, rad, thermostat). However the problem still exists. There is no sign of fluid cross contamination- but I am now thinking head gasket? Any thoughts from TD5 experts?
Post #643111 11th Aug 2017 7:36am
Head gasket or crack in the head Sad
Post #643112 11th Aug 2017 7:37am
fondelli
Thanks- Is there any difference in the level of pressure created by both issues- ie is one normally greater than the other?
Post #643118 11th Aug 2017 8:08am
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
During last 2 year I was repairing several TD5 with coolant loss - typical is bad hose clips, chuffed hoses, bad expansion cap or another leak. And because of the placement of hoses, the leaking coolant can fully evaporate without any drips od road.
My solution, how to find this, was to disconnect the thin tube from expansion bottle and pressurize the cooling system with air up to aprox. 1 Bar. Without running engine, I can hear and see some drops or escaping air.
So try this first, before dismantling engine. Start with only 0,5 Bar of air pressure.
In the expansion bottle cap, there is a valve, opening at 1,4 Bar. "Drobek" = The Small One - Discovery 2, "BlufĂ­nek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #643119 11th Aug 2017 8:22am
fondelli
Thanks for this- expansion tank/cap are new.
Post #643126 11th Aug 2017 8:35am
stigomery
United Kingdom 2004 Defender 90 Td5 HT Belize Green
You say the cooling system is pressurising? If you run the engine, then let it cool down, and then open the expansion tank, is it pressurised when cold? If yes, that's you head gasket I'm afraid.
Get a garage to "sniff" the coolant, a quick check and they'll soon tell you if the coolant is contiminated.
Had exactly the same issue with my Td5 at 90k miles
Post #643127 11th Aug 2017 8:44am
fondelli
Thanks to everyone - so far. Will investigate further. I just want to rule out any peripheral issues before the head comes off.
Post #643141 11th Aug 2017 10:43am
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
Hi mate, I'm sure you know this but make sure it is OAT (red) coolant when you fill up Thumbs Up
Post #643239 11th Aug 2017 6:45pm
fondelli
update
Well- latest is that head came off and was pressure tested. A nice crack in one of the ports- so not the usual place. New head needed.
Post #646123 24th Aug 2017 7:13pm
stigomery
Bummer mate, I dread to think how much I've forked out in the first 18 months of ownership! Right now I'm praying I ain't got more trouble with my own head.
Post #646142 24th Aug 2017 8:32pm
