Home > Td5 > Rear Driving Member Bolts snapped
kweese
Canada 1999 Defender 110 Td5 SW Belize Green
I recently noticed that my rear wheel was leaking grease. Upon removing the wheel all the bolts on the drive member were broken off. What could have caused this?
Post #641944 4th Aug 2017 10:26pm
ibexman
Loose bolts
Post #641945 4th Aug 2017 10:30pm
Overtightening, failure to tighten them properly, or the wrong bolts. It's not unknown for this to happen.
Post #641947 4th Aug 2017 10:32pm
Lionel
Australia
I like to check these every 20,000km, as they can work loose. I have found them to remain tight if I have spring washers under the bolt heads. Important to torque them up using a tension wrench to avoid overtightening & stretching of the threads.
Cheers,
Lionel
Post #642673 9th Aug 2017 3:01am
Worth bearing in mind that these are supposed to be grade 10.9 HT, not the more common 8.8 HT. If someone has at some time replaced the original bolts with 8.8s, it might explain your situation.
Post #642726 9th Aug 2017 11:11am
Lionel
Australia
Very good point, blackwolf!
Cheers,
Lionel
Post #642881 10th Aug 2017 2:38am
The easy solution:-
Socket head caps, which are grade 10.9 as standard, with spring washers not thread lock, and in holes that are scrupulously clean.
Post #642899 10th Aug 2017 8:29am
kweese
Thanks everyone!
Post #643350 12th Aug 2017 5:27am
