Home > Maintenance & Modifications > Optimill quick release boss issues
bear100
Hi all Mr. Green have any of you that have fitted the optimill quick release boss had issues with it rattling? Fitted mine a week or so and it's starting to rattling on the two mating sections, was a solid fit when first fitted Big Cry
I've noticed they have removed them and the lock from the website and they haven't returned my email Shocked 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #642814 9th Aug 2017 7:03pm
dioliahary
Purchased one recently, fits great, no rattling. However it is a taste difficult to get on, not sure why seems I have to heavy push it on rather glide
Post #642816 9th Aug 2017 7:26pm
bear100
lovely bit of kit and the lock looks and feels good too, mine glides on really nice and not stiff at all, just the annoying rattle, unfortunately i am one of those types who have to fix it Neutral 2023 Defender L663 V8
Post #642818 9th Aug 2017 7:35pm
Chris90V8
England 1987 Defender 90 2.5 TD XS CSW Portofino Red
....mine's been On Off On etc etc for 6 months now
No rattles from mine Rolling Eyes 🚜. ...... . .... . .. 🚗🚐🚛🚚🚚🚗🚙🚐
Post #642830 9th Aug 2017 8:38pm
bear100
That's good news! Just hope I have a faulty unit and they will replace it 2023 Defender L663 V8
Post #642834 9th Aug 2017 8:40pm
Paul55
England 2008 Defender 90 Puma 2.4 XS CSW Santorini Black
No rattles on mine either, tight fit, bit of a Censored to put on sometimes, the knack to it is just make sure it's square on to the boss and it slips on Thumbs Up Cogito ergo sum
Post #642835 9th Aug 2017 8:44pm
bear100
Sounds like mine could be a bit to loose because it's extremely easy to put on Shocked 2023 Defender L663 V8
Post #642836 9th Aug 2017 9:12pm
Mine rattled until I filled the front tyres with Dynabeads, mind you everything including me rattled until l filled the front tyres with Dynabeads!
Post #642857 9th Aug 2017 10:26pm
bear100
Are those Dynabeads any good? Any Pros and cons 2023 Defender L663 V8
Post #642864 9th Aug 2017 10:48pm
Absolutely magical on my Defender, I don't know why I didn't bung them in years ago!
Post #642877 9th Aug 2017 11:41pm
Grenadier
Just read up on Dynabeads, never heard of them before. BW, how are they fitted? Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #642888 10th Aug 2017 7:00am
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Your best bet is speak to optimil directly I'm sure they will rectify any issue asap 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #642895 10th Aug 2017 7:40am
In one of two ways, depending on what suits best.
Either you bung them in the tyre when the tyre is fitted (or pop the tyre bead and insert them that way). In this case you can use the larger size dynabead which is recommended for 4x4 and truck tyres.
Alternatively if the tyre is on the wheel and you don't want to break the tyre bead, you use the smaller "standard" size dynabead and insert them from a little bottle with a short plastic hose through the valve stem, after removing the valve core. It's a little bit fiddly (and very boring since it takes a few minutes per wheel) but easy, then you replace the valve core and reinflate the tyre.
For my 255/85x16 BFG KM2s the bead supplier recommends 6.5 ounces of beads, which is what I put in. When driving, you get a little bit of a shake initially as the beads find their place at start up, but they do seem to make a huge difference. My tyres as they wore had become unbalanced to the extent that driving above 50 was profoundly unpleasant with everything shaking and rattling, and I really didn't think that the beads could solve this though I thought they might help. Now it is comfortable back up to the legal max.
Better still, since the balancing is dynamic, as the tyres continue to wear the beads simply sort themselves out and maintain the balance, whereas fixed weights won't. In my case, my Blindos won't really take fixed weights anyway.
All in all they seem to work far better than I had dared to hope, I am definitely a convert.
Post #642900 10th Aug 2017 8:37am
stephan123
I fitted the Optimill QR boss about 3 months ago and noticed one of the two pins is slightly loose which i can feel when turning the steering wheel in a particular direction. Bothered me at first but have since got used to it. Otherwise very impressed with the build quality.
Post #642983 10th Aug 2017 5:57pm
gilarion
Removed post as link not working. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #642989 10th Aug 2017 6:33pm
