![]() | Home > Maintenance & Modifications > Work Lights - What have you got?? |
JustFX Member Since: 10 Nov 2016 Location: Mendip Hills Posts: 190 ![]() ![]() ![]() |
My setup is just two LED units I bought from the local Lorry Drivers accessories type place. They are £25 each and are LED and are rather bright (12W each).
http://www.ksccuk.co.uk/shop-page/45882049...p/10032050 ![]() Click image to enlarge ![]() |
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 ![]() ![]() |
arran,
far corners make a number plate light plinth that you can bolt a work light on to. search their website |
arran jones Member Since: 21 Nov 2016 Location: south west Posts: 728 ![]() ![]() |
Found it..
Thanks giles ![]() |
Butchers Boy Member Since: 10 Jan 2016 Location: Essex Posts: 426 ![]() ![]() ![]() |
![]() Click image to enlarge That's what I ended up doing! Brilliant! ![]() Click image to enlarge 2010 Defender 90 HT The longer I live..... The better I was! |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5139 ![]() ![]() ![]() |
I have a very bright LED Work light fitted; I also connected it to the reversing light. Soon after I had to disconnect it as when pulling up to reverse park on roads I was blinding the motorists behind me, some of whom were rather annoyed with me.
![]() I then wired the light to the reverse light circuit with an on off switch so now no more road rage incidents. ![]() http://www.youtube.com/user/conwy1 |
Timcat Member Since: 20 Jul 2016 Location: Rugby at the moment Posts: 1025 ![]() ![]() ![]() |
S17 with the same remote as Vee Tee, great if wired with a switch in the cab, we leave it switched on & turn it off via the remote so when in the RTT in remote places we can turn the light on via the remote brilliant!
A single S17 at the rear of the truck. Night test results.
1. In the off position. ![]() Click image to enlarge 2. In the on position. ![]() Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
