![]() | Home > Puma (Tdci) > Brake Fluid Change |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2025 ![]() ![]() ![]() |
Sorry to hijack the thread
![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
rob369 Member Since: 05 Feb 2014 Location: eastbourne Posts: 17 ![]() ![]() ![]() |
2 years is recommended
Ohhhh had mine 7 years and it's never been done
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
It should be enough but get a spare litre. If you dont open it, it will last for a while
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
Brake fluid will last longer than two years. The problem is it absorbs moisure which can boil if you need to brake hard, which then gives you brake fade. You can test it with a moisture tester, a lot of garages just do that these days rather than routinely replace it. Replacing also flushes out some of the muck in there too mind you, so i tend to change it every couple of years.
It should be enough, but the fluid is cheap enough. You don't need any fancy (expensive) DOT5 stuff either, just normal DOT4 will do, it's all Land Rover recomend. Most brake fluid exceeds DOT4 anyway, that's just the minimum standard they put on the bottle, you'd be hard pushed to find anything that only just met DOT4. |
Lightningtweeds Member Since: 16 May 2017 Location: Fintry Posts: 461 ![]() ![]() ![]() |
You wont need 1 Litre.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20937 ![]() ![]() |
I once had my fluid at 4 years because I didn't k is it should be two and no one included it in servicing.
![]() I now get it done every two years, I agree on it taking in moisture and when replaced you can ever so slightly tell the difference. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Brake pipes seem to demand a refresh every Mot?
Thanks for all the helpful input I will probably buy an extra bottle to be on the safe side and get on with it shortly.
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1342 ![]() ![]() ![]() |
Hi Rob369,
May be teaching mother to suck eggs, but if you carefully draw off a lot of the old fluid from the master cylinder with a syringe before pouring in the new, you can get away with using less of the new fluid. ( Yorkshireman speaking with deep pockets and short arms ![]() Just make sure you don't draw off too much and allow air into the master cylinder, otherwise bleeding can become more of a task. Changed mine last year when the 110 was 4 years old. Thought it would do the system good to have some fresh fluid pumped through and it was a chance to free off the bleed nipples. |
It's not so much about using less fluid, but it certainly means you're not pushing manky stuff through the system when you don't need to.
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 982 ![]() ![]() |
FYI garages just flush the first foot or so out of each wheel. The reasoning is that that is the only bit that air can get to. So to do it professionally, you won't need much.
Merlin |
I think the reasoning is more to do with it being cheaper to only spend 10 minutes doing it.
Thanks for the benefit of your experience chaps is helps boost confidence on projects. Cheers!
