Home > Td5 > Td5 2004 orange liquid leak
neverin
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Hi, I'm a bit of a novice here but can anyone offer some guidance on this orange liquid.
Post #637650 15th Jul 2017 3:40pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Coolant leak, possibly from the steel Bung under the exhaust manifold?
Have you checked your expansion bottle level?
Also a quick check of all hoses wouldn't go amiss by the looks of it! 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #637656 15th Jul 2017 3:57pm
dorsetsmith
coolant leak check top hose from head to the rad
Post #637667 15th Jul 2017 4:28pm
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
Definitely coolant....as above Thumbs Up
Post #637685 15th Jul 2017 6:12pm
neverin
ive been tightening the jubilee clips on the coolant pipes but there is still some weeping from both places, i take it the jubilee clips should work?
Post #642051 5th Aug 2017 6:19pm
cobra_mark
United Kingdom 2000 Defender 90 300 Tdi SW Barolo Black
I used the Landrover clip and a jubilee clip on the top hose, prime place to leak.
Post #642072 5th Aug 2017 8:19pm
cobra_mark
Post #642074 5th Aug 2017 8:20pm
LR90XS2011
as its a 2004 it may be that the hose is ready to be changed and is damaged due to age where is seals. New hose, clean up where it fits (if needed) new clips and its all good to go DEFENDER 90 TDCI XS,
Post #642141 6th Aug 2017 6:14am
