![]() | Home > Technical > twin alternator v8 |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6216 ![]() ![]() ![]() |
Did it years ago with a couple of friends V8's (used to run twin alternator'd Tdi's too), works great if you do heavy winching, as you keep the winch battery totally isolated from the main vehicle battery.
anyway, the v8 is dead easy as all the parts are available off the shelf (or form a breakers yard) If you V8 doesn't have aircon, then you just need to get the "aircon equipped" bracketry, as they (LR) moved the alternator to a different position and fit the AC compressor where your current alternator is. then you just need the correct length belt and away you go. this is for V belt engines... I don't know if the serpentine is the same. |
