![]() | Home > Maintenance & Modifications > 110 CSW roof lining |
Hi Scott Landy,
I stripped down my puma CSW last year to fit sound proofing. Given how long I spent in it you'd think I'd have a clearer idea, but it's not crystal I'm afraid. However, from recollection I don't think you can get the end panel out without taking out what you already have, but also the middle panel. Additionally I think you have to take off the plastic trim to get the panels off as well, otherwise the flex required to pop out their lower edges might crease the middle of the panel, you wouldn't want that. With the plastic trim out you just have a small lip of metal around the roofline to get the panel out. Even that requires some bending and flexing of the panel. Sadly, I don't think you can get the end panel out without doing the middle panel and window/pillar trim I'm afraid, no shortcut. That's only my experience, others might offer a quicker route to follow. Good luck. ![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347 ![]() ![]() ![]() |
Again puma experience.
You'll probably need to remove trim and middle panel not front one tho. Good luck. |
110 CSW '96 experience:
Indeed, you have to take all out. The front of the rear panel goes under the middle panel and they are fixed together to the roof bar with the fir trees. I did not take the plastic side trim panels out, but loosened the fixings at the top only. It requires some flexing of the roof lining to get it out though... Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Scott_Landy Member Since: 24 Aug 2015 Location: Cheshire Posts: 85 ![]() ![]() ![]() |
Thanks for that. I'll have a crack at it! At least I'm not going mad!
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
On the later ones (i'm pretty sure they all use the same floppy headlining), you remove the middle section as it goes over the front and rear sections. but you'll only need to pull the clips out and shove it forward a bit to drop the rear down.
Buy all new fir trees though, they don't like being reused. |
