Home > Off Topic > Creeper boards?
lambert.the.farmer
England 1998 Defender 90 300 Tdi PU Rutland Red
Creeper boards?
Hi all. I am on with relaying the drive to get a good flat service area. As part of this i have found a set of 615mm jack stands rated at 6 tonne which is more than adequate even for the heavy lead lined cherokee. These will then afford me the luxury of a creeper board but which one there's hundreds to choose from? I am a big bloke and I am heavy for my size because of all the manual farming so what ever i get needs to be robust. It could also benefit from having relatively big wheels as while the new surface it will run on is flat it does have joints. So what are people using that's worth a recommendation? Cheers in advance. Rhubarb and custard let fly with their secret weapon.
Post #641795 4th Aug 2017 4:05am
williamthedog
The thing I found with them is if you have a tight bolt your swinging on you tend to move around.
I just use a old exercise mat that I've acquired. Thumbs Up
Post #641804 4th Aug 2017 5:27am
lambert.the.farmer
Interesting point to consider. Cheers. Though for greasing and waxoyle application it should be cleaner than crawling around on the floor. Rhubarb and custard let fly with their secret weapon.
Post #641808 4th Aug 2017 5:38am
discomog
Heavy duty version!
 Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #641817 4th Aug 2017 7:23am
An old big sheet of cardboard is useful too, slippy and disposable if messed up.
A creeper is no use to me at all due to grit and gravel stuff.
They are ideally suited to perfect floors ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #641851 4th Aug 2017 11:28am
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
I was a HGV Technician and I used a creeper alot, the best i found was one call 'The Bone' it would roll on gravel and was really strong.
It was alot better than even the snap on ones that get stuck on a small pebble!
I managed to find mine cheap as they was selling them off, there not cheap but they are fantastic!
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #641858 4th Aug 2017 12:12pm
Like Steve, I tend to use a flat-packed large cardboard box. Not only is it clean (at least to start with) it is also provides just enough padding to be comfortable and it insulates you from the ground. When it gets scabby, it goes in the cardboard recycling bin and is replaced by a new giant box.
Post #641860 4th Aug 2017 12:15pm
Rashers
And obviously the more goodies you buy for your truck, the more cardboxes you have to use Thumbs Up
Post #641861 4th Aug 2017 12:20pm
^^^^ Laughing ____\We|Will|Win/___
Post #641871 4th Aug 2017 1:03pm
Absolutely! Thumbs Up
Post #641875 4th Aug 2017 1:21pm
lambert.the.farmer
Being a poor farmer my drive is not covered unfortunately and also being a farmer dry days are at a premium for other jobs so cardboard is out. As is the current situation of the waterproof onesie as like overalls they try to either give you a wedgie or strangle you. At least with a creeper i will be up off the ground.
I will look into the bone.
Cheers all. Rhubarb and custard let fly with their secret weapon.
Post #641932 4th Aug 2017 8:06pm
Cupboard
Rolling with laughter I use the thick cardboard too
And when I worked on a farm that had a creeper (Draper I think) that never got used because we always used cardboard.
Post #642192 6th Aug 2017 10:04am
