Home > Technical > Bulkhead to windscreen seal
dioliahary
I am in the process of renewing my bulkheads vent flaps seals, this led me to change the old bulkhead to windscreen brackets (don't even go there) Now in turn I have noticed the relatively poor condition of the window to bulkhead seal.
Can I get away with applying some sort of silka flex onto this seal? To smarten up.
I have other projects ongoing and really don't want to start removing headlining, roof bolts to fit a new seal.
Already gong to have the bulkhead touched up by a sprayer as there is a little collateral damage to the paint Shocked
Any experiences/advice
Post #641266 1st Aug 2017 10:10pm
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
I used Sikaflex 291i over the foam seal and it seems to have worked well. It doesn't look too obvious and has definitely reduced the amount of water in the footwell. At the same time I put a dob of it behind the windscreen brackets just to reduce the chances of water coming in through the bolt holes.
Post #641360 2nd Aug 2017 11:12am
Procta
I think most defenders now have had some sort of sealant, mine I think is going to need some for the door seals, water seems to like to come through behind, at the tops of the doors. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #641398 2nd Aug 2017 2:52pm
Hendrix
England 2013 Defender 110 Puma 2.2 USW Santorini Black
Even my Puma leaked here from almost new but a neat little run of silicon did the trick and you dont notice unless you actually look for it.
Post #641405 2nd Aug 2017 3:21pm
dioliahary
Was tbinking of prising the window frame up slightly and cutting a notch in the new foam seal where the bulkhead lugs are so no need to liftthe roof and windscreen up too much, then pressing home with some sealant, bit lazy but...
Post #641406 2nd Aug 2017 3:22pm
Balvaig
Wouldn't recommend prising the windscreen up. If you start disturbing seals then you are likely to get more leaks elsewhere. I used Captain Tollies creeping crack cure on mine. Worked, otherwise I was going to use black sealant along the joint.
Post #641411 2nd Aug 2017 3:45pm
dioliahary
Another thought would be to extract the existing perishing seal, seal and slide in the new seal then seal again
Post #641420 2nd Aug 2017 4:24pm
gilarion
I do not think you could do that at the new seal is very soft, more like sponge rubber. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #641430 2nd Aug 2017 5:10pm
dioliahary
Been out again tonight and the existing seal/ Sealant is not too bad
I am going to tidy up and make good with some sika flex and leave the gasket renewal for another day...
Post #641485 2nd Aug 2017 9:32pm
dioliahary
Thanks for your advice, I have finished fitting new vent foam seal
with a touch of silicone as back up, new stainless hinge pins, new bulkhead to windscreen hinges. A rub down and paint and I am quite pleased. Well living in Manchester, this may be optimistic, just need some warm weather to test. Only worry is that the seals hold and do their job.
Post #642533 8th Aug 2017 9:27am
SonicFields
Re: Bulkhead to windscreen seal
Just wondered the reason for not going there, was it a problem trying to realign the new brackets?
Post #642546 8th Aug 2017 10:55am
dioliahary
No the job itself was really easy just that one thing seems to lead to another and whilst I was tinkering I was slowly damaging the surrounding paint, which had just been resprayed. It seems I am totally incapable of just sticking to one job at a time.
Post #642591 8th Aug 2017 5:03pm
Balvaig
Looks good now though. Very Happy
Post #642607 8th Aug 2017 6:59pm
dioliahary
Thanks, early signs of water ingress though. Drivers side water dripping onto the floor...not sure where to go with this one yet. It all looks well sealed up. Hmmm
Post #642619 8th Aug 2017 7:26pm
gilarion
Could it be the door seal?
Sometimes they have a tendency to allow water in and it travels along the door stay and drips onto the foot well For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #642626 8th Aug 2017 8:12pm
