Home > Puma (Tdci) > Hazards flashing when I hit a bump
Deadeye
South Africa 2008 Defender 110 Puma 2.4 SW Zambezi Silver
Hello all. I have been having an issue with my 2008 2.4 tdci defender whereby when I hit a bump that the hazard lights come on and the doors unlock. Granted I drive a lot of crappy roads and hit a lot of bumps but even rumble strips seem to upset her. Any ideas what it could be? Thanks in advance for the help!
Post #641233 1st Aug 2017 8:24pm
Fifth Horseman
The alarm module has an inertia switch that in the event of an impact will unlock the doors and flash the hazard lights. It sounds like yours is a bit over sensitive - its not adjustable though. Check the alarm module is secured properly to the bulkhead as if its not then this may lead to this.
Post #641252 1st Aug 2017 9:08pm
Deadeye
So I was told this somewhere else as well but apparently the 2.4 doesn't have an inertia switch. I bought one and searched around on the bulk head but it wasn't there. It's driving me nuts!
Post #641316 2nd Aug 2017 6:43am
Fifth Horseman
It�s built into the 10AS alarm module. The separate inertia switch was only for the TD5 and was on the bulkhead in the engine bay it operated the fuel pump cut-off IIRC
Post #641346 2nd Aug 2017 10:16am
^^ Are your sure about that?
I have never seen anything to suggest that the AS10 has any form of movement detection built in, and there are no references to such a feature that I know of in any Landrover or Lucas literature. Furthermore, if your Defender is struck while parked, or whilst driving with the doors locked, I do not believe that the doors unlock (there was a time in the early days of central locking when this was a favourite approach of thieves - bang the car and it unlocks - so it was discontinued pronto). It would also probably be activating constantly when driving off road if this feature existed.
The inertia switch is provided when a vehicle has an electric fuel pump and its purpose is to reduce the risk of fire by shutting the pump off. The TD5 Defender has one for this reason, whilst the 2,4 TDCi does not. I imagine that the 2.2 TDCi probably does, but I've never looked.
I don't however think that the AS10 is clever enough to do this, and think it is more likely that it is due to water ingress into the AS10, or a loose connection or intermittent ground fault somewhere. It could even be a fob malfunction.
Post #641370 2nd Aug 2017 12:41pm
srod
It sounds like quite a fun feature. I wish mine did this!
Post #641377 2nd Aug 2017 12:59pm
Deadeye
Luckily the fuel doesn't cut off as well otherwise I would come to a grinding halt. It is indeed the rough roads that make it go off. I have checked all loose wiring and grounding and everything seems fine. I have a sneaky suspicion that it may have been in accident in the past which have maybe upset something somewhere though.
Where would I find the as10 alarm module? Please excuse ignorance, life was way easier with my old 200tdi!
Post #641379 2nd Aug 2017 1:02pm
Fifth Horseman
I believe it is correct (although I may be wrong - it wouldn�t be the first time Confused ) but I can�t remember where I found that information. Inside the 10AS there is a unit which I believe to be the inertia switch - I will upload a photo when I get home later today.
Regards your comment about the doors not unlocking on impact when the vehicle is parked, to inhibit this would be one reason why the alarm has a switched ignition feed, the other would be to stop it activating whist driving.
Agreed water ingress or loose connection could also be the cause.
Post #641380 2nd Aug 2017 1:04pm
Fifth Horseman
You should be able to find the 10AS unit behind the front right hand speaker.
blackwolf - The inertia switch is the green & beige cube top right of the PCB (it is not present on 10AS units without central locking).
Useful 10AS info here http://www.gomog.com/allmorgan/LandRoverSecurityManual.pdf
Quote from Topix:
The anti-theft system module also incorporates an internal inertia switch. In the event of an impact of sufficient severity to trigger the inertia switch when the ignition switch is in position II, the anti-theft system module will unlock all doors and operate the hazard flashers. The anti-theft system module will remain in this mode of operation for 2 minutes. To de-activate the hazard flashers and restore the anti-theft system module to its normal mode of operation, the ignition switch should be turned to position 0 and back to position II after the 2 minute period has expired.
Post #641452 2nd Aug 2017 7:44pm
Well I never knew that! Thank you for posting the photo and link.
It could well be the answer to the OP's symptoms in that case.
Post #641497 2nd Aug 2017 10:38pm
Grenadier
I'm still having ongoing hazard/indicator problems, similar to Deadeye with a couple of associated issues. Will take a look at this. Ta. Thumbs Up
Interestingly, have a fair bit of rust on the bolts on the bulkhead, just alongside the speaker, and often have water in the footwell directly below after heavy rain, which I think is coming from a bad windscreen frame-to-bulkhead seal. As such, I wonder if Blackwolf's thoughts that water ingress could be a cause might also have some mileage. TBC Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #641525 3rd Aug 2017 6:59am
Deadeye
Thanks Fifth horseman have been trying to sort for at least a year now! If it is Censored would it be a case of just replacing it or would it need reprogramming?
For your help as payment you're always welcome to pitch your tent in the garden if you're ever passing through zambia!
Post #641535 3rd Aug 2017 8:16am
dorsetsmith
Post #641540 3rd Aug 2017 8:43am
Gonarezhou
South Africa 2015 Defender 110 Puma 2.2 SW Alaska White
Fith Horseman - you are clearly very clued up on the 10AS system! I have a recent problem starting where at odd times I have to press the unlock button twice and the indicator lights do not flash. There is no problem on the locking side. Do you think this is a module problem? The vehicle is still under warranty so I am happy to argue the case for a replacement.
Post #641548 3rd Aug 2017 10:20am
Fifth Horseman
I certainly wouldn�t call myself an expert!
Gonarezhou - Needing a double press and no indicator flash is the system telling you the remote (plip) battery is low. It�s detailed in the owners handbook.
Deadeye - thanks for the offer but it�s probably a bit far south for me. If it�s replaced the new unit will need reprogramming to match it with the remotes and the engine ecu.
The alarm unit is vulnerable to water damage in its location, although it wouldn�t be if the windscreen �seal� actually worked. A simple drip shield from plastic sheet looped over the unit (as suggested by someone on this forum some time ago) would provide a fair degree of protection from water.
At least a fried 10AS unit is relatively cheap to replace, unlike say the transfer box control module on a D3 which is also known for taking swimming lessons.
Post #641575 3rd Aug 2017 12:58pm
