Home > In Car Electronics > Tracking down the Tracker
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
As one of its security layers my DCPU has a GPS tracker box - one of these http://digitalcomtech.com/wp-content/uploads/2015/08/syrus_ds.pdf was fitted by a previous owner and I've maintained the subscription. Its been fine for almost a year but now has stopped working and, according to the online logs, was last contactable at 13:32 on July 11th, when it correctly reported its location as my works car park.
I'd like to fix it, but so far I've not been able to find it Confused Ordinarily this would be a good thing from a security perspective but its a bit annoying at the moment... No joy in the seatboxes or anywhere obvious in the engine compartment. I've found the antenna, whose cable disappears into the headlining. I'm starting to wonder whether the control box has been hidden up there but haven't yet mustered the enthusiasm to investigate.
Any ideas as to other likely hiding places?
Post #641285 1st Aug 2017 11:04pm
Chris90V8
England 1987 Defender 90 2.5 TD XS CSW Portofino Red
Keep following the antenna..... Thumbs Up 🚜. ...... . .... . .. 🚗🚐🚛🚚🚚🚗🚙🚐
Post #641309 2nd Aug 2017 5:09am
huffhuff
United Kingdom 2001 Defender 90 Td5 HT Java Black
Follow the breadcrumbs... Maybe the odd tug to see if you can hear some movement. Headlinging is only held up with a few fir trees... seems to be the likely place.
So, if you find it there, move it somewhere less obvious Smile TD5 Defender 90
Discovery 3 HSE
Post #641336 2nd Aug 2017 9:16am
I believe that above the headlining is usually the first place that the thieves look, since this is where the many trackers are fitted.
Post #641342 2nd Aug 2017 10:07am
Intercept
Tracker box now found - not in headlining Smile
The original supplier: Carrotech http://www.visionairegps.co.uk/ upon hearing of the problem immediately offered a replacement in return for the old unit. No warranty nonsense (I have no idea when it was purchased) and help via email several times during the weekend.
I'm impressed with this level of service!
Post #642284 6th Aug 2017 10:02pm
Chris90V8
Nice one... Glad ya got it sorted Thumbs Up 🚜. ...... . .... . .. 🚗🚐🚛🚚🚚🚗🚙🚐
Post #642299 6th Aug 2017 10:33pm
Intercept
Update
It was fitted in 2010. The box was delivered to the supplier today and I can see from the tracker map that the replacement is already at their local post office (running on its internal battery) waiting for collection and should be delivered back to me tomorrow. Excellent service!
The problem turned out to be the fault of the mobile network - nothing wrong with the unit itself.
Post #642597 8th Aug 2017 5:47pm
