Home > Maintenance & Modifications > Changing rear discs. Anything else worth doing?
greenlandrover
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Tonga Green
As the title says, I need to change rear pads and discs.
Just wondering if it's worth doing anything else while it's all off?
Cheers,
Jason
Post #641267 1st Aug 2017 10:13pm
Replace your wheel bearings and convert it to the tdi type with 2 big nuts! QRZ 2e0vpf
Post #641268 1st Aug 2017 10:15pm
bear100
Check bearings, check pistons on calliper and paint the hub Very Happy 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #641271 1st Aug 2017 10:26pm
greenlandrover
Cheers Greeni and Bear100,
Whats the difference between the Puma and the Tdi ones please?
Post #641272 1st Aug 2017 10:27pm
Stacey007
When mine was done the other week I got new rear drive flanges,
Much better no 'nock' when you come off the power. £16 each side for Oem
Post #641279 1st Aug 2017 10:47pm
I haven't got time at mo to explain, but found this, sorry Thumbs Up
https://forums.lr4x4.com/topic/57761-td5-wheel-bearings/ QRZ 2e0vpf
Post #641280 1st Aug 2017 10:48pm
AndyT66
England 2004 Defender 90 2.5 TD XS CSW Zambezi Silver
I did the two brake mudshield plates, they were 14 years old mind and very flakey
Post #641287 1st Aug 2017 11:10pm
greenlandrover
Thanks for the link Greeni Thumbs Up
AndyT66 thank for that tip. The ones on there are looking a bit rough.
Post #641310 2nd Aug 2017 6:13am
Lotus_esprit_s1
Go down to the local breakers and buy two 300tdi disco or 300tdi 90 halfshafts and fit them instead of the two piece ones.
Post #641435 2nd Aug 2017 5:22pm
roel
I did take all 4 off, I didn't see a point keeping them. Roel
2003 90 Td5 (2009-now)
Post #641659 3rd Aug 2017 5:42pm
greenlandrover
I've had a quick nosey around the web and can't see the difference.
How do the Puma ones differ to the Tdi ones please? Which bit is the two piece part?
Excuse my ignorance Embarassed Laughing
Cheers,
Jason
Post #641672 3rd Aug 2017 6:30pm
Lotus_esprit_s1
The late td5 / Puma half shafts are two piece with separate drive flanges - these flanges and shafts always wear and get slop in them causing the usual driveline bonk. Landrover sorted this problem out on the 300tdi's with the one piece halfshafts with integral drive member, but for some reason went back to the two piece shafts in early /mid 2000's, possibly to rationalise and use th same halfshafts as the 110 when they ditched the Salisbury. I think they may have reverted back to one piece shafts again with the late pumas?
Ive had four late td5's and a Puma and swapping to the 300tdi shafts is always the first thing I do to them when I've bought them and it is always a big improvement even if they don't seem that worn.
Here's a link to paddocks but breakers are full of them and can't give them away usually!
http://www.paddockspares.com/ftc3271-rear-...lange.html
Post #641951 4th Aug 2017 11:11pm
greenlandrover
Thanks Lotus_esprit_s1 Bow down
You learn something new every day when owning a Defender! Laughing
Sounds like a good idea to change them whilst doing the brakes Thumbs Up
Post #641975 5th Aug 2017 8:27am
sako243
Um 300Tdis weren't integral shafts, certainly not on 110s and Salisbury axles. Seperate drive flanges and shafts, should know as I've currently got them sat in the shed. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #642018 5th Aug 2017 2:02pm
Lotus_esprit_s1
I was referring to 90's as the original poster has a 90.
Post #642227 6th Aug 2017 2:11pm
