Home > Td5 > Brake Servo
Tank
Scotland 2004 Defender 90 Td5 HT Zermatt Silver
Brake Servo
Hi
Brakes work but have a rock hard pedal. Garage said the servo is not creating a vacuum so change the servo?
How easy is it to change the servo and how long does it take.
Where is the best place to get a new servo? Britpart ok?
Tank
Post #641095 1st Aug 2017 10:27am
Devon-Rover
Unbolt master cylinder from servo -- remove vac pipe and unbolt servo from pedal box -- Shuffle master cylinder forward a little -- Remove the servo
Refitting is the reversal of removal. If you fancy a bit more wiggaling room then you can prop the bonnet fully open and use a bungee to stop it falling on you or just simply remove the bonnet.
The servo's have a habit of cracking round the bolts so the vacuum leaks out. I would recommend a TRW or equiv branded servo.
Post #641104 1st Aug 2017 10:56am
Tank
Thank you, sounds simple Smile
Ta
Post #641107 1st Aug 2017 11:04am
bankz5152
Yup TRW or Genuine, remember they are your brakes you don't want to skimp out on cheap parts that may fail!
Post #641126 1st Aug 2017 11:41am
