Home > Technical > Am I missing something? : Jammed ignition
Farmer58za
South Africa 2012 Defender 90 Puma 2.2 SW Tamar Blue
Hi all
This afternoon, I managed to set off my ('12) defender alarm. After about an eternity (15 seconds), I got the thing switched off. During that time I put the key in the slot turned the ignition on and pressed the fob button, switched it off removed the key, pressed the fob button again. When the alarm eventually stopped, I tried to start the car normally and the ignition was jammed. The key would turn just enough to release the steering lock, but no further. It took about 15 minutes, maybe more, of jiggling, rocking of the key, with a whole lot of of WD40 to get it free. After that it seemed to work alright.......
Is there some funny security ignition lock procedure that is automatically activated with the alarm, or am I looking at a simple mechanical fault in the key barrel?
Thanks
David Dave's not here man...
Post #636279 7th Jul 2017 8:29pm
It's entirely mechanical. No electrickery or secret handshakes involved. Darren
Post #636281 7th Jul 2017 8:37pm
spudfan
Ireland
If you had been lucky enough to mention this to your dealer while under warranty they would have replaced the barrel. It's a recognised fault. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #641101 1st Aug 2017 10:44am
Farmer58za
Nope, vehicle was purchased 2nd hand Neutral Dave's not here man...
Post #641110 1st Aug 2017 11:07am
spudfan
Ireland
Happened to me OUT of warranty Sad 1982 88" 2.25 diesel
Post #641117 1st Aug 2017 11:30am
Farmer58za
Did you replace the whole steering lock only and end up with an extra key on your keyring? Dave's not here man...
Post #641119 1st Aug 2017 11:33am
spudfan
Ireland
Whole steering lock was replaced, with new keys. 1982 88" 2.25 diesel
Post #641122 1st Aug 2017 11:35am
