![]() | Home > Technical > How do you remove the center console on the puma? |
mse,will prob know,you could pm him. 2.4 90 XS
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2111 ![]() ![]() ![]() |
mlightfoot,
PM me your e-mail. I can send you the instructions to remove it. regards Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
mlightfoot Member Since: 10 Jan 2009 Location: Cheshire Posts: 86 ![]() ![]() ![]() |
Thanks Eduardo, just pm'd it to you!
neil Member Since: 18 Dec 2008 Location: Wiltshire Posts: 56 ![]() ![]() ![]() |
Unscrew the 2 torque screws on the front face and give it a gentle tug - it should all unclip; well mide did anyway!
mse Member Since: 06 Apr 2008 Location: UK Posts: 5111 ![]() ![]() ![]() |
Agree (remove the stereo etc) Mike |
Could you sent me too (I PM you my email) Thanks Daniele |
Bomber82 Member Since: 20 Oct 2009 Location: Alessandria - Italy Posts: 216 ![]() ![]() ![]() |
Hi, I've sent you my e-mail, could you send me too? Thanks Matteo Defender 110 Td4 SE MY 09 |
Mad Cow Member Since: 27 Oct 2009 Location: Hertfordshire Posts: 292 ![]() ![]() ![]() |
Eduardo
Could you send me the instructions too, i've PM'ed my email address. Thanks MAD COW 2007 90 Hard Top - 2009 BMW F800GS - 2002 CCM 604E Dual Sport Project90 |
lacordaire Member Since: 22 Nov 2009 Location: Brasil Posts: 2 ![]() ![]() |
Eduardo
Could you send me the instructions too please, i've send my email address by PM. Thanks a lot, Laco. |
g�ktu Member Since: 27 Sep 2011 Location: T�rkiye Posts: 20 ![]() ![]() ![]() |
hi all
its an old post but I'll need this instruction, too:) |
Remove Stereo, using U shaped stereo removal tool (most car shops sell one) undo the two obvious Torx bolts, starting at the bottom insert the wifes best plastic spatular and lever out, repeat on the opposite side, move up abpout 2/3rds of the console and repeat. Undo all wires remembering where they came off for all of ten minutes. Replacement is easy apart from you will have forgot which plug goes where.
![]() 110 HCPU Tipper |
coxman Member Since: 01 Nov 2013 Location: Hong Kong Posts: 14 ![]() |
I want to know too..
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
Remove the two screws and then pull from the top. It's clipped in at the top. It can be pulled out with the radio in place of you just want to look behind it.
thanks Roy
I presume certain force should apply to PULL the console and unclip it ? I worry to break into half |
