Home > Td5 > TD5 Coolant quantity/type
excossack
Time to replace the coolant.
So how many litres are needed and is it worth buying neat/concentrate or pre-mixed?
From what I have read its Red OAT coolant required?
Is there a more transparent header tank available or is mine just a few years old and just not as transparent as it should be.? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #640895 31st Jul 2017 1:45pm
bankz5152
Red OAT. They are opaque from new.
Post #640905 31st Jul 2017 2:31pm
excossack
Cheers.
So one these four?
http://www.halfords.com/webapp/wcs/stores/...rn=s162brc 1999 Defender TD5 110
Regards
John M0VAZ
Post #640910 31st Jul 2017 2:44pm
bankz5152
Yup. Premixed or mix yourself.
TD5 takes around 11 litres if you drain the entire system to zero. Round about 5 litres if you drain the majority
Post #640914 31st Jul 2017 2:53pm
excossack
So a drain, flush through and then 5L of premix and top with water. 1999 Defender TD5 110
Regards
John M0VAZ
Post #640924 31st Jul 2017 3:20pm
bankz5152
No. Premixed is, premixed, you just poor it in.
Post #640925 31st Jul 2017 3:31pm
excossack
If I was to drain out more than 5L and filled with premix but still needed to top up, I would top with water. 1999 Defender TD5 110
Regards
John M0VAZ
Post #640927 31st Jul 2017 4:02pm
miker
For the price difference it makes more sense to buy concentrate. put 5l in then fill the rest with water.
It's a pretty hard system to drain properly. When I first did mine I kept finding pockets of yellow/green fluid! Had to bust off several pipes and flush through with loads of water.
Post #640935 31st Jul 2017 4:32pm
excossack
Dropped the coolant yesterday and swapped the thermostat. Gave the rad a flush and the heater matrix as well. Gone clean water out.
Got 5l of red OAT in and 2.5l of water.
Went to undo the bleed screw and managed to break the rubber so now the bleed screw does not seal...... so a new hose needed. Sad 1999 Defender TD5 110
Regards
John M0VAZ
Post #643550 13th Aug 2017 5:29am
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
Hi excossack
same happened to me with bleed screw. Brought new one from dealer and managed to get a purchase on broken screw that was left in and slowly unwound it. Even tried to drill it out but eventually used pliers (thin nose) and got it out that way to Hugh relief Thumbs Up
Post #643708 13th Aug 2017 9:19pm
