![]() | Home > Maintenance & Modifications > Cost of upgrade for higher final gearing on my 90 |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 ![]() ![]() ![]() |
Cheaper to buy a disco 2 transfer box or speak to Shabs piercy at synchro gearboxes 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2239 ![]() ![]() ![]() |
Yep. Shabs or Ashcroft buy a Disco box from them or buy a used box and have a garage fit it. Depends how much you want to spend really.
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967 ![]() ![]() |
Around £900 supplied fitted by Ashcroft
Lotus_esprit_s1 Member Since: 01 Oct 2014 Location: Uk Posts: 201 ![]() |
Or £75 for a used disco transfer box (they very rarely fail) and couple of hundred for fitting, or do it yourself with som help to lift into place.
JR Member Since: 07 Dec 2012 Location: Auchtermuchty Posts: 532 ![]() ![]() ![]() |
As Lotus Esprit says, I'm on my 2nd Disco 1 transfer box in the last 10 years.
Bear in mind you'll need to change over the Diff Lock mechanism. Also the D2 transfer box is different as the D2 does not have the diff lock activation kit as standard although the early ones do have the external drive for the linkage which the facelift doesn't. The D2 diff ratio is fractionally higher geared and has 'Quiet Gears' fitted, as does the Tdci Defender transfer box! |
