Home > Maintenance & Modifications > Bulkhead vent flaps
Page 2 of 2 <12
Retroanaconda
No on the flaps, as above.
Post #639509 24th Jul 2017 9:41pm
dioliahary
Beltin now at the risk of being a pain.
Foam seals glued to the vents only?
Just read a thread where they stuck foam to the flap and rubber to the bulkhead
http://www.defendersource.com/forum/f6/ven...43884.html
Post #639517 24th Jul 2017 10:03pm
Retroanaconda
Early vehicles used rubber seals which fixed to be bulkhead. Later ones used foam seals which stick to the flaps.
Some people convert to the older type as an 'upgrade'. However there's nothing wrong with the later seals, and they look much tidier in my opinion. Yes they will need replacing after 5-10 years as they perish/harden but the rubber seals are exposed to UV and will also degrade so will also need replacing at some point.
Use whichever style takes your fancy, both will work.
Post #639828 26th Jul 2017 11:24am
Procta
can you fit forms with out the need for removing the vent flap? I am sure the driver side one has seen better days, i am looking at working on the quick fixes at the moment. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #654679 3rd Oct 2017 8:33pm
legin
United Kingdom 2012 Defender 90 Puma 2.2 HT Santorini Black
One of the things I miss from my old defenders, why could they not keep them on the puma ?
Post #654687 3rd Oct 2017 8:54pm
Procta
They are well handy to have in the summer, Here is a funny story for you regarding these vents, When I bought 1st bought my landy, I never checked that the vents were shut properly at all, after a good two months or so driving up and down a 70 mph road with the very cold wind blowing through the front vents etc and here's me thinking that the heater takes and age to warm up. I thought about adding a plug in heater thing just to keep warm! It wasn't until my mum happened to walk past and clock that my vents were a good few mill up compared to theirs, she then twigged on about me saying about how cold it was. The handles were down about 3 to 4 clicks! so no the wonder procta here was turning to brass! Shocked
So do make sure lads that they are well closed up for the winter! Last thing you want is to be brass monkeys going to work! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #654693 3rd Oct 2017 9:08pm
dioliahary
Rolling with laughter yep mine all buttoned down for winter. Ended up fitting rubber seals.
Post #654708 3rd Oct 2017 9:59pm
donmacn
I'm a regular messiah today - lots of thread resurrections....
After the advice and decision to fit foam, why go for rubber?? I think I'm going to need to have a look at mine again, so would like to go for whatever really does seal the best.
Ta
Donald Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #672240 20th Dec 2017 3:54pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
Re: Bulkhead vent flaps
dioliahary wrote:
Mine are stuck down, painted over and do not work.
It gets rather hot in the defender when sunny, how useful is it to have the air vents working.
Thinking about stripping and cleaning.
It's sunny in Manchester Shocked
Post #672312 20th Dec 2017 7:47pm
dioliahary
Changed from foam to rubber as it had a slight leak that showed itself in the drivers footwell. So foam was probably fine but as it had rubber originally replacing with rubber kept in line with original. Still got my leak btw.
Post #672343 20th Dec 2017 9:28pm
Page 2 of 2 <12
