Home > Maintenance & Modifications > Cable entry for light bar
bear100
Hi all
I am soon to wire up at last!! A roof rack mounted Laser light bar, what is the best route to run the cable, it leaks enough as it is with out adding a hole to the roof Shocked are there any other ideas? I have a RAI so might fit that and utilise it some how?
What have you done? 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #639639 25th Jul 2017 3:26pm
zsd-puma
I'm planning on fitting one eventually. I would just run the cable in through the top of the air intake then bring it out into the inner wing.
Post #639644 25th Jul 2017 3:48pm
If you have a RAI / Snorkel and rack run it down the outside of it, but nearest the windscreen pillar out of sight.
You barely notice it and is common practice with extended breathers.
Plastic zip ties will do fine.
You can terminate the ends with heatshrink to prevent water ingress down the convoluted tube also.
That will take you down and into the engine bay, but it might be a tight fit if you go too big with the tube or wiring.
Soft PVC sheath may be an option in that case if need be.
In the engine bay, youcan take and in-line fused feed directly from the alternator rather than going all the way back to the battery. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #639650 25th Jul 2017 4:21pm
VeeTee
Netherlands
As custom90steve says, I have run it along the raised air intake in a black conduit pipe, then under the bonnet.
 Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #639656 25th Jul 2017 4:40pm
bankz5152
Equipe 4x4 do pillar "cable tidies" which I was planning on using for an extra neat look.
https://www.trekoverland.com/products/land...x4-cmv0083
Post #639676 25th Jul 2017 6:14pm
Interesting product ^^^^^
I see no reason at all as to why that could not be bonded on, especially as it's just a cable protector.
I'd avoid drilling the pillar, I never did with my Safari and made a custom bracket. ____\We|Will|Win/___
Post #639679 25th Jul 2017 6:24pm
bankz5152
Very true, though if its bonded would be annoying to remove/add cables should you ever need to.
Interested in this custom bracket tho any piccys?
Post #639685 25th Jul 2017 6:43pm
bear100
Thanks guys, their only that puts me off is having to drill into the pilla for the RAI Shocked that pretty much the reason I haven't fitted it 2023 Defender L663 V8
Post #639740 25th Jul 2017 9:45pm
3mm IIRC Stainless 'L' section.
I have painted it, but not on mating faces an it is bonded on.
After intitial during no problems at all. Nor any drilling.
Can't see any issue with the cable thing myself?
Surely you can cable thread in situ?
I'd definitely consider bonding on as well. ____\We|Will|Win/___
Post #639747 25th Jul 2017 10:01pm
bear100
Oooh I liked that idea! What did you use for bonding? Sickaflex? 2023 Defender L663 V8
Post #639757 25th Jul 2017 10:31pm
Yes, Sika as recommended.
Many people swear by it but personally I don't like it or it's finish so finished of with a quality neutral cure black Silicone.
Regardless, no issues in any way. Thumbs Up ____\We|Will|Win/___
Post #639765 25th Jul 2017 11:02pm
Procta
What me and my dad did with his, we ran the wire through the top of the snorkel and then through the out though the system in the engine bay, then up behind the dash to where it needed to get power from. who ever had wired it in before, had ran the wire behind the door seal and into the dash. So water was just Censored in! They added the earth to one of the window screen bolts too, So it was a very untidy job and a half arsed one too!
So we practically overhauled the full lot. We replaced the toggle switch with a three way switch. So that the rear lights could come on separately. I moved the earth to the steering column support, so it was out of sight. All looks a nice neat little job now. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #639770 25th Jul 2017 11:20pm
bear100
Ah so actually inside the RAI itself? Does it rattle at all? I presume you glanded it just behind the wing 2023 Defender L663 V8
Post #640095 27th Jul 2017 12:05pm
excossack
Do you have a rear ladder? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #640109 27th Jul 2017 1:36pm
bear100
No.......not yet Shocked what's your thoughts? 2023 Defender L663 V8
Post #640172 27th Jul 2017 7:38pm
