Home > Maintenance & Modifications > Spare wheel carriers?
skwdenyer
United Kingdom 1987 Defender 110 V8 Petrol CSW Alpine White
Hi there. Long-time lurker, finally got my long-broken 1987 V8 110 CSW back on the road, now need to keep the momentum up with a "rolling restoration." So after a little help.
My doors are not of the best Smile I'm looking at a spare wheel carrier, having upgraded to 235 tyres. I was looking at the Simmonites unit as being simple and apparently pretty robust.
What are others' thoughts? Price is a major issue (there's a lot to do to the beast)...
Post #639157 23rd Jul 2017 3:54pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
I have had this one on two defenders.
http://www.island-4x4.co.uk/spare-wheel-ca...-4342.html
No issues other than occasionally need adjustment. I have had my current one four years and no sign of corrosion.
Post #639206 23rd Jul 2017 6:38pm
skwdenyer
Thank you. Does it require drilling, or just pick up existing holes?
Post #639218 23rd Jul 2017 7:19pm
Scotm
You need to drill out existing rivet under the rear side window to make the hole bigger for bolt and a new hole next to it.
Post #639221 23rd Jul 2017 7:27pm
skwdenyer
Thanks. Since I've just picked up a Brownchurch roof rack, which has support bars which pick up on that same rivet, I'll need to see if I can double up on the mounting points!
Post #639318 23rd Jul 2017 11:44pm
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
might be of use to you: http://www.defender2.net/forum/topic53927.html 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #639323 24th Jul 2017 12:34am
skwdenyer
Thank you.
Post #639325 24th Jul 2017 1:26am
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
I have the Bearmach swing away carrier.
Works OK, powedercoat is crap.
I also had to modify the plate that fits the back door as it had been made in 'mirror image' of what it should have been.
Chris
Post #639350 24th Jul 2017 8:47am
OlavLRD110
Estonia 2003 Defender 110 Td5 CSW Baltic Blue
Locable, stainless steel.
Available, but in Estonia.
Price 300.- without delivery.
Post #639356 24th Jul 2017 11:13am
skwdenyer
Hi OlavLRD110
Interesting. I'm a fan of stainless steel!
Do you mean it is available to buy there? If so, do you mind if I ask where? I might be able to find somebody in Estonia to buy one (depending upon cost of course).
Or do you mean you are selling that one?
Post #639422 24th Jul 2017 6:08pm
leeds
The best swingaway wheel carrier is the stainless steel Nakatanenga wheelcarrier available in naked stainless or black powder coated stainless steel. Available here
However that maybe a bit more then the OP wants to pay
For a mild steel carrier I would recommend a Safari Equip one which can come just powder coated, galvanised or galvanised and powder coated. Has grease nipples and large mounting plates. Available here
We have both on our vehicles.
Brendan
Post #639499 24th Jul 2017 9:21pm
JWL
I've also got a swingaway wheel carrier on my 110 and it's got a Brownchurch rack with the support bars on as well. i fitted the wheel carrier brackets as per instructions with the support bar out of the way then altered the bar to fit on top of the carrier bracket by chopping it off at the bottom and welding the chopped off bit to match up with a hole I drilled in the bracket under the window.
Not the best of pictures but they should give you the idea
Post #639541 24th Jul 2017 11:50pm
