![]() | Home > For Sale & Wanted > [For Sale] Mobile storage draws |
windymiller Member Since: 03 Oct 2013 Location: farnham Posts: 223 ![]() ![]() |
Open to sensible offers Bump
big ives Member Since: 24 Dec 2013 Location: Northern Ireland Posts: 128 ![]() ![]() |
what's the actual sizes?
I am looking for ONE set of these to fit in my 90 CSW, I have inward facing rear seats, HOWEVER I have one seat removed and I THINK one set these boxes would fit in the space vacated by the seat, that's my plan if the measurements are correct?........................................cheers Ivan |
kzycnn Member Since: 24 Apr 2009 Location: Northumberland Posts: 277 ![]() ![]() ![]() |
Hi Ivan
They are 440mm wide. I have them in the back of my 110 - excellent bits of kit. Recently had a wanted ad on here for a single flipper (but MSS finally came through). Tony |
Give me a shout Ivan ,they really are great storage ..
Mark |
Mark
please send me a private message with your email and I will contact you...............................cheers Ivan |
Mark
As I said I have a 90 CSW with one of the rear inward seats removed, in the space I would like to fit a storage box at least one on top of each like you have advertised , however as you know the space is limited. When fitted in you landy had you them fitted in the same place on top of the wheel arch box so that one sat on the wheel arch box, the other sat on top just up past the window (well in my case a window) but you should get my drift. The other issue I am aboard offshore getting back to the UK 4th August when I can take measurements to see if they are good for me. So if you could give me length depth and height that would be great, I will be honest with you if the measurements fit my space I WILL BY ONE SET FROM YOU ![]() ![]() ![]() Also my internet here on the rig in Malaysia is having issues for over a week, as sometimes I can’t send or open PMs on my landy forums. I see you sent a PM but at the minute I can get it to open but will keep trying to open it. ![]() ![]() ![]() ![]() ![]() Very best regards Ivan |
No Problem they are 440 wide and designed specifically for the defender wheel arches the bottom box is deeper to fit into the recess of the bodywork
,you can fit 2 boxes deep on a 90 they are brilliant and very useful Give me a shout when you get your messages |
