Home > Maintenance & Modifications > Extra switches
Blaserman
England 2011 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
Extra switches
Hi guys
Does any one know where I can get some extra switches from to go in the dash on my 110. I want two for the aux spots which are going on the rack and one for the rear seat entertianment so I can isolate them from the front. Given I have the double cab there are lots of blank switch covers in the dash and the neatest way of sorting my problem would be with the same sort of switch that LR use.
Thank you in advance
Rob
Post #63871 16th Mar 2011 8:42am
mse
There are a few posts on this including how to wire them...try a search Mike
Post #63875 16th Mar 2011 9:13am
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
Post #63889 16th Mar 2011 11:07am
Paul_1978
England 2004 Defender 90 Td5 CSW Zermatt Silver
Mudstuff do a range of none genuine switches with lables on them, lots of pictures of them been fitted in landys, on the Puma dash, they have fitted them down the sides rather than the front of the dash, looks very neat.
http://www.mudstuff.co.uk/Carling_Switches.shtml
Check the picture out at the bottom of the page on the link above.
Post #63892 16th Mar 2011 11:36am
taffrican
Wales 2002 Defender 90 Td5 HT Java Black
Try these guys, they are a lot cheaper than mudstuff, same switches and excellent service, I cannot recommend them enough Thumbs Up
http://www.dun-bri.com
Post #65446 28th Mar 2011 10:22pm
leeds
Just be careful when mixing components such as switches from different suppliers.
Have found out that whereas some switches look/possibly have same overall dimensions the actual cut out sizes can be different.
Get a switch panel from one supplier and switches from another and they may or may not be compatible.
Brendan
PS Just like rear bumperettes and swing away wheel carriers
Post #65461 29th Mar 2011 8:51am
