![]() | Home > Puma (Tdci) > Aircon Evaporator freezing |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 786 ![]() ![]() ![]() |
Hmm... Based on what you've told us, it's either the sensor on the cooling coil or the cooling coil is already dirty and needs a cleaning.
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 339 ![]() ![]() ![]() |
Sensor on the evaporator, it's a common enough issue that L/R have changed the part at least three times and have a tech bulletin covering it: https://www.defender2.net/gallery/albums/u...0icing.pdf
Its a pig of a job to replace as the a/c has to be degassed then the heater needs to come out and be dismantled to replace the sensor. |
Not to mention that the whole dash board needs to be disassembled and then re-assembled after all is said and done. Please note the new positioning of the sensor on the coil and the proper part numbers.
Good luck and let us know how it works out for you. |
That's liable to happen on any air-con left at 'max' setting.
Do you turn it down after a few minutes at 'max'? ![]() |
Hendrix Member Since: 04 Oct 2016 Location: North Notts Posts: 106 ![]() ![]() ![]() |
Have had something similar on long run with aircon on low speed, after couple of hours aircon stops working and temperature goes up. Switch off for little while and then back on and away she goes again. Sounds like same issue. Mine is 2013 model however and i note the bulletin only goes up to 2012
xpertoftheseas Member Since: 05 Jan 2016 Location: Salisbury, Wilts Posts: 164 ![]() ![]() ![]() |
Glad this baby is still under warranty! Thanks for all the confimations gents which confirms my suspicions. As we are in northern Corsica right now it's not the best time for this bad boy to fail. However luckily it is manageable.
As we live in the sunny paradise of the UK I have never had this issue, but these 35degree days are testing the Defender to say the least. LR can do this the same time as the GB/TB oli seal that was found leaking during the inspection last week. Greetings from beautiful Northern Corsica... My 10th Land Rover, but my first Defender. |
Just had the 110 back from the dealers after having the rear oil seal replaced under warranty. They found the drain pipe from the evaporator blocked, and it seems that the condensate backed up and caused the evaporator to freeze.
Something worth checking before a long trip to hot climate. Back to the dealers tomorrow as now the clutch bites as soon as you lift the peddle, and the peddle travels about half way before doing anything to the clutch! Damn Defenders! My 10th Land Rover, but my first Defender. |
